Cisco 6509 sup 720 %FM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
rahulb212
Hi All,
we had a 3000 lines of ACL that is applied to the interface ,
CPU on the switch spiking to 100% and i see below logs on the switch.
CPU seems to 100% for most of the time ,  for temporary fix we removed the acl which bought down the CPU utilization , but my management wants to put the ACL back in ,
Mar 13 21:27:18.373 GMT: %FM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
Mar 13 21:28:45.242 GMT: %FM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
Mar 13 21:32:13.804 GMT: %FM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
Mar 13 21:35:53.314 GMT: %FM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
Mar 13 21:38:42.647 GMT: %FM-4-TCAM_ENTRY: Hardware TCAM entry capacity exceeded
Could some one help me in fixing this issue
this could be a bug, which IOS version are you running ?
Check if your switch supports the command:
;mls acl tcam share-global'
if so, issue that command and reload the device. Also, (obviously) make sure that 'ip cef' is enabled...
thanks, we have maintenance scheduled next week, I will make changes as recommended.
Leo Laohoo
Please post the complete output to the command "sh version".
I'd be looking at upgrading the firmware of the chassis.
R1.VDC-FO.QA1#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 18-Jul-11 05:49 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
R1.VDC-FO.QA1 uptime is 50 weeks, 6 days, 19 hours, 30 minutes
Uptime for this control processor is 50 weeks, 6 days, 19 hours, 17 minutes
Time since R1.VDC-FO.QA1 switched to active is 50 weeks, 6 days, 19 hours, 24 minutes
System returned to ROM by reload at 17:43:33 GMT Fri Mar 31 2017 (SP by reload)
System restarted at 18:33:01 GMT Fri Mar 31 2017
System image file is "sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI7.bin"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.2) with 983008K/65536K bytes of memory.
Processor board ID
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
30 Virtual Ethernet interfaces
74 Gigabit Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
