10-10-2015 09:16 PM - edited 03-08-2019 02:09 AM
Hello,Anyone could advise is there any downtime impacted to the LAN client devices if I reboot one of my active supervisor engine to standby supervisor engine on Cisco6509. Will it be seemless to the LAN client devices?
10-10-2015 09:51 PM
If you reboot your standby supervisor no. If you reboot your active supervisor, it will have impact just for a short period of time. Some seconds.
Make sure your standby supervisor works properly by "show redundancy" command and SSO is set.
Hope it helps.
10-11-2015 06:56 AM
Thanks for your reply. So it means it not seemless and there will be drop of packets in terms of active/standby supervisor engine switchover for Cisco 6509.
10-11-2015 07:09 AM
Yes, you will have some drops depending on your configuration. If SSO mode is set, downtime would be short. Around 1 to 10 seconds. But if RTR is set, downtime will be more than 30 seconds.
Masoud,
10-11-2015 07:19 AM
Being seemless is relative. It will be seeless for a bunch of users browsing web, but it will not for some applications which even are sensitive to some drops. I usually have 4 to 7 ICMP timeout when I switch. I suggest you to do it in downtime.
