Cisco 6509 Supervisor failover - How long?
jonathanaxford
Level 3
Level 3
Hi All,
Just a quick question...
How long would you expect a failover from one Supervisor card to the Slave supervisor card to take?
We have a Cisco 6509 with the following:
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B
6 2 Supervisor Engine 720 (Hot) WS-SUP720-3B
When the Active card was 'pulled' by an engineer, the switch rebooted and took a good 5 minutes or so to come back online.
I would have expected a much quicker failover myself...
Anything we need to check or are missing?
Many thanks
Jonathan
17 Replies 17
By the looks of it, the 6509 is not configured for NSF. I will get this implemented before we run the test again to see if it has an effect.
Many thanks
Don't forget to make sure you look at the neighboring routers...
I would be tempted to plan the NSF config, but do a test first to try to see where delays are.
SSO should be sub second, but thene there are potential SPT issues, and then OSPF itself.
I always like to know *why* something did not work, instead of just seeing it go away IYSWIM...
P.
Definately, I will get to the bottom of this. I also like to ensure that i understand everything so it can't bite me again next time!
I will schedule in NSF config, and also plan for the next down time and failover of the cards so i can make some exact timings and see what is going on.
Thanks for all your help on this one.
Cheers
Jonathan
