Cisco 6509 with SUP 720 cpu utilization is high
kiran_8095
From couple of weeks we have observed the cpu utilization of cisco 6509 with SUP 720 is high. During daytime from 9:00 to 21:00 it keeps increasing & reaches 98% & after 21:00 becomes normal. We are unable to find the root cause for this behaviour. Any suggestions is welcome.  Attached is show version & show proc cpu history.
Kiran
5 Replies 5
sanjeevmahadani
Hi Kiran,
Pls. increase memory which is 64 mb only.
65536K bytes ( of Flash internal SIMM (Sector size 512K).
Hi Sanjeev,
Thanks for your suggestion. But how is this related to High CPU utilization?
Kiran
I am sorry Kiran,
IT was just information.
kiran_8095
Hi Everyone,
Any suggestions to find the reason for high CPU.
Kiran
Hello Kiran,
there was an Ask the expert event about this kind of issues
see
https://supportforums.cisco.com/message/3536828#3536828
also
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
more specific for C6500 the following:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml
note:
you can use
show proc cpu sorted
to see the processes that use most resources first
Edit:
in your case most of cpu resources are taken by interrupts   ( the second number after the '/' represents interrupts)
show processes cpu
CPU utilization for five seconds: 49%/45%<<<<; one minute: 52%; five minutes: 50%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
====> this means traffic that is process switched and sent to the cpu instead of being processed in hardware
see also
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
follow the document below it should be helpful are the slides associated to the ask the expert event
https://supportforums.cisco.com/docs/DOC-21945
Hope to help
Giuseppe
