Cisco 6513 switch boot to ROMmon.
axus123456
i have a Cisco 6513 it is used one, i have tryed to boot it but it did not work,
it alwayes go to rommon mode and i am not able to know what is the issue,
when it boot i get the below outpot from the switch.
System Bootstrap, Version 8.1(3)
Copyright (c) 1994-2004 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Clearing autoboot state machine
Reading monitor variables from NVRAM
Warning: Rommon NVRAM area is corrupted. Initialize the area to default values
Reset reason 0xffff.
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
rommon 1 >
i have tryed the following comands,
rommon 1 > boot
boot: cannot determine first file name on device "bootflash:"
rommon 2 >
and this
rommon 3 > set
PS1=rommon ! >
?=0
so please help me with this issue,
thanks in advance
Mahesh Gohil
Level 7
Level 7
Try below command in rommon
dev    hit enter
it shows files in different disks, check if file you want to boot with is availab le there if so run below command
For example: boot bootflash: hit enter
If no file displayed may be no file available to boot
Regards # Mahesh
Dear Mahesh,
thanks for your help,
I tried the command and below is the result.
rommon 1 > dev
Devices in device table:
        id  name
bootflash:  boot flash
    disk0:  PCMCIA Disk 0
    disk1:  PCMCIA Disk 1
    eprom:  eprom
any way thank you for your replay.
Can you do the following commands and post the result:
dir bootflash:
dir slot0:
dir slot1:
