04-01-2015 07:40 AM - edited 03-07-2019 11:21 PM
Hi all
am having core swtich 6807 with below ios
System image file is "bootdisk:s2t54-ipbasek9-mz.SPA.151-2.SY1.bin"
I need to upgrade it to s2t54-adventerprisek9-mz.SPA.151-2.SY2.bin.
1- Can i upgrade it normally using tftp server (copy tftp flash:bootdisk) <-- is this directory correct?
2- and then issue the command boot system flash bootdisk:s2t54-adventerprisek9-mz.SPA.151-2.SY2.bin
OR there is something relate to FPD image or any thing else ???
Please feedback and correct me with steps above if available.
regards,
Solved! Go to Solution.
04-01-2015 02:17 PM
Yes.
Yes. You can also copy the IOS via USB.
But most importantly, please check the config-registry value. If you want to take advantage of the boot variable string then the config-registry value should be "0x2102".
04-01-2015 02:17 PM
Yes.
