Cisco 6807-XL License Issue
Hi There,
  We are deploying Cisco 6807-XL and below is the show version output.
Cisco IOS Software, s6t64 Software (s6t64-ADVENTERPRISEK9-M), Version 15.3(1)SY2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 01-Dec-16 23:20 by prod_rel_team
ROM: System Bootstrap, Version 15.3(04r)SYS, RELEASE SOFTWARE
Switch uptime is 1 week, 23 hours, 46 minutes
Uptime for this control processor is 5 days, 21 hours, 49 minutes
System returned to ROM by Stateful Switchover at 15:52:46 SGT Fri May 11 2018
System image file is "bootdisk:/s6t64-adventerprisek9-mz.SPA.153-1.SY2.bin"
Last reload reason: Admin CLI
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C6807-XL ( Intel(R) Core(TM) i3-3227U CPU @ 2.50GHz ) processor (revision ) with 2879487K/524288K bytes of memory.
Processor board ID FGE21432SSD
Processor signature 0xA9060300
Last reset from s/w reset
165 Virtual Ethernet interfaces
96 Gigabit Ethernet interfaces
17 Ten Gigabit Ethernet interfaces
4 Forty Gigabit Ethernet interfaces
3833840K bytes of USB Flash bootdisk (Read/Write)
Current IOS using is s6t64-adventerprisek9-mz.SPA.153-1.SY2.bin. When I try to check the license status using show license command it failed to work. Also I don't see option to install license.
#show license
% Invalid input detected at '^' marker.
#license install
Thanks in Advance
BR+
Prashanth
Leo Laohoo
Currently, the Sup6T has Advanced Enterprise license activated. It cannot go any higher than that.
Hi Leo,
  Thanks for the feedback. How to confirm the license activated in 6870-XL. Because generally for the other catalyst series we have
show license
command to check this.
Prashanth
prasany@sg.ibm.com wrote:
Hi Leo,
Post the complete output to the command "sh version".
switch#sh version
switch uptime is 1 week, 1 day, 1 hour, 57 minutes
Uptime for this control processor is 1 hour, 6 minutes
Last reload reason: reload
export@cisco.com.
Last reset from push button
switch#
