Cisco 6807XL - Radian_Monitor_PLL PLL reset Failed
PaulT
Hi Community,
Currently experiencing the below error, and I wasn't able to locate anything online with regards to the error.
Switch (Catalyst 6807XL) appears to be functioning as expected, though we began receiving the below error in the Logs this morning.
08:37:11.207 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:13.371 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:15.531 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:17.691 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:19.879 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:22.051 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:24.211 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:26.371 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:28.551 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:30.731 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
08:37:32.995 FW[MOD 21]: radian_monitor_pll:: port_num[0] unit[0] bcmport[1] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
Has anyone seen this before and know the fix?
Thank you
Paul
Leo Laohoo
Is there a FWSM?
No, there isn't a FWSM.
