Cisco 7204VXR - Image upgrade problem
mbaylis
Level 3
Level 3
Is there anyway to download a image to a Cisco 7204 VXr router when you are in the ROMmon mode?
I know you can use the xmodem and tftpdnld but these commands don't seem to work on this router? We have a PCMCIA card installed but the router did not seem to recoginse the card (before i was in the ROMmon mode) in slot 0/1. Came up with "device not ready"
Can anyone help?
manmeetmarwah
Level 3
Level 3
You will probably find the information required by you at the following link:
http://www.cisco.com/en/US/partner/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
Manmeet
