04-17-2018 09:18 AM - edited 03-08-2019 02:41 PM
Hi Frdz,
We have CISCO7609-S (M8500) with RSP720, We observed below error with config register value.
Configuration register is 0x2102 (will be 0x0 at next reload)
------------------ show version ------------------
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 18-Jan-17 06:12 by prod_rel_team
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
Current Processor Information :
Active Location = slot 5
Current Software state = ACTIVE
Uptime in current state = 31 weeks, 4 days, 8 hours, 2 minutes
Image Version = Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc1)
BOOT = disk0:/c7600rsp72043-adventerprisek9-mz.155-3.S5.bin,1;disk0:c7600rsp72043-adventerprisek9-mz.122-33.SRE13.bin,1;
Configuration register = 0x2102 (will be 0x0 at next reload)
Peer (slot: unavailable) information is not available because it is in 'DISABLED' state
Pls suggest.
Thanks in advance.
Vijay
04-17-2018 10:02 AM
Please check this link:
Hope it is useful
04-18-2018 10:05 AM
Thanks Julio.
04-18-2018 11:03 AM
You are welcome, please keep us posted about the TAC resolution.
04-17-2018 03:23 PM
Raise a TAC Case. I think the supervisor card is toast.
04-18-2018 10:07 AM
Hi Leo,
I have raised TAC case with Cisco, I will let you know tac analysis.
04-19-2018 08:01 AM
Hi Team,
Here is TAC update:
Problem Description:
Config-register change.
Analysis:
config-register is a unique config command. It actually does not require a write mem to take effect. The config-register is a persistent rommon variable and is used to determine the boot sequence. It should not change on power cycle or reload.
Apr 19 15:38:42.928 IST: %DIAG-SP-6-TEST_RUNNING: Module 5: Running TestNvramBatteryMonitor{ID=34} ...
Apr 19 15:38:42.928 IST: %DIAG-SP-6-TEST_OK: Module 5: TestNvramBatteryMonitor{ID=34} has completed successfully
And per the fallowing registeres, they confirms that the NVRAM battery is fine.
“In the output, look at register values [FE080050] and [FE080054]. If the register value [FE080050] is above 0000 it confirms that SP runs with low NVRAM”
So since the configuration register has been changed successfully , and you were able to save the configuration , then we can confirm that the device is fine.
Action Plan:
Keep your eye on the device, if the config register has been changed again then we need to check the NVRAM again, for now the NVRAM is fine and is not pointing to any issue.
>> We followed below POA.
Also we need to proceed with the following action plan
1- Try to change the config register again to the old value 0x2102
2- Save the configuration --- > please let me know if you get any error message during the saving process
3- We need to test the nvram using the following
Run the test using the following command
diagnostic start module 5 test TestNvramBatteryMonitor
then collect the following outputs
show diagnostic result module 5 test testNvramBatteryMonitor detail
show logging
show version
remote login switch
show platform hardware asicreg naboo all.
Vijay
