cisco 800 - domain-lookup problem
birka.izik
hi
i try to configure DNS on cisco 800 , it's worked , but after 24 hours the command ip domain-lookup change to disable, and it stop work
i'm not understanding why it's happen ,
that's the configuration
ip domain name XXXXXX.CC.CC
ip host XXX-RR-FF.com 2.2.2.2
ip name-server 1.1.1.1
ip dns view default
dns forwarder XXXXX
dns forwarding source-interface FastEthernet4
ip dns server
when i configured like that evrything workd , but about 24 hours later
the configuration change by her self to
no ip domain-lookup
ip dns view default
no dns forwarding
dns forwarder XXXXX
ip dns server
help please ??
Peter Paluch
Izik,
The configuration on IOS does not change on its own. It must have been changed by an external modification. Are you sure you have not deactivated it yourself? Are you the only one who has administrative access to the router?
Best regards,
Peter
