Cisco 800 router (none wireless) guest network configuration
Shumaid01
I'm new to Cisco,
I have a cisco router with four ports on it, it is configured to provide access to one internal network
I need to configure one of the ports to provide a separate guest network access to internet only and prevent this network from accessing the internal one
Your guidance is much appreciated
Thank you
Shumaid01
After researching, I have my todo list to start configuring the router:
- Create a vlan
- Assgin one of the ports to the vlan
- Assgin an IP (10.10.20.0 /24) to that vlan
- Disable inter-vlan routing
- Configure DHCP on the vlan
If I do the list above, would the cleints connect to this guest network and get internet access? or I have to do additional configuration
Thank you
