Module, PFC3 & MSFC3 malfunctioning
rj.kapildev
Community Member
Hi..
I gotta issue in ma switch WS-C6506-E, any possibilities to resolve tis issue ?? As even the user impact s there   Didn't rebooted since as switch is in critical network, on top of that incase of minor error vanish-off in rebooting, whereas here we facing major error on both primary vs secondary switch, any suggestion would be great and most welcome...
Mod Ports Card Type                              Model              Serial No.
5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1420HTU6
Mod MAC addresses                       Hw    Fw           Sw           Status
5  ----------------------------   5.10  8.5(3)       12.2(33)SXH8 MajFail
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       ---------------  4.1    PwrDown
  2  Centralized Forwarding Card WS-F6700-CFC      ----------------  4.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       ----------------  4.1    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       -----------------  2.6    MajFail
  5  MSFC3 Daughterboard         WS-SUP720          -----------------  4.1    MajFail
Mod  Online Diag Status
  1  Not Applicable
  2  Minor Error
  3  Minor Error
  5  Major Error
Thanks in advance.
glen.grant
  There is no way around it you are going to take some downtime.  Get a show tech and open a tac case , most likely the supervisor will have to be replaced , make sure they send you the new supervisor , pfc, and msfc cards .  They like to send them separate so you may have to put them together , usually there is instructions. Also check and make sure all power supplies and inputs look ok .
glen.grant
Thanks for your suggestion ...
