CISCO 800 - routing between 2 VLANs
rivantsiv
We have a simple CISCO configuration which consists of 2 VLANs:
VLAN Name                             Status    Ports
1    default                          active    Fa0, Fa1, Fa2, Fa3, Fa4, Fa5
2    VLAN0002                         active    Fa6, Fa7
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Interfaces:
interface Vlan1
 description LAN interface
 ip address 192.168.244.1 255.255.255.0
 ip flow ingress
 ip flow egress
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
interface Vlan2
 ip address 192.168.243.1 255.255.255.0
 ip nat inside
The problem is:
1. Computers connected to Vlan1 can ping 192.168.244.1 and 192.168.243.1 but cannot ping any computers in Vlan2.
2. Computers connected to Vlan2 can ping 192.168.244.1 and 192.168.243.1 but cannot ping any computers in Vlan1.
Probably I am missing some routing pathes ?
Tried this:
ip route 192.168.243.0 255.255.255.0 Vlan2 permanent
ip route 192.168.244.0 255.255.255.0 Vlan1 permanent
with no luck.
Mark Malone
You should not need statics to communicate with layer 3 vlans on the same router, have you turned on ip routing
Can you ping 192.168.243.1 source of 192.168.244.1
Mark Malone
Thank you Mark. You just made it firm clear for me that static routes were not necessary. Digged deeper - the problem was not related to cisco configuration at all. Looked like I tried to ping some of our WIFI access points and they did not have the default gateway set up to point to 192.168.243.1/192.168.244.1 respectively.
