Cisco 800M Series Router, not connecting WAN
vivek
i have a just bought a Cisco 800M Series router, i have a Leased line with Static ip. i want to connect my WAN through the static ip but it is not connecting. also where to enter the gateway of leased line.
Please help me. how to connect it through Static ip
Thanks in advance.
post the config you have so far.
What is your WAN connection, the GigabitEthernet, the serial interface ?
7 Replies 7
Static IP settings
ip Address 117.240.94.19
Subnet mask 255.255.255.248
default gateway 117.240.94.17
i am using its Quick Setup.
GigabitEthernet.
make sure you are on the right interface. The GigabitEthernet WAN Interfaces are
0/8 and 0/9 for the Cisco C841M-8X ISR, and 0/4 to 0/5 for the Cisco C841M-4X
The config would look like this:
interface GigabitEthernet0/8
 ip address 117.240.94.19 255.255.255.248
The default route would be:
ip route 0.0.0.0 0.0.0.0 117.240.94.17
its Cisco C841M-4X
but i didnt get you.
can u tell me step be step configuration ?
have a look at the link below. This is all done from the command line.
Configuring Gigabit Ethernet WAN Interfaces
http://www.cisco.com/c/en/us/td/docs/routers/access/800M/software/800MSCG/routconf.html#59429
How to do without command prompt through Cisco Configuration Professional link i.e. 10.10.10.1
Please guide.
otherwise how to go to command line ?
go to Chapter 5 of the attached guide, it has detailed instructions on how to configure the WAN Ethernet interfaces:
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/cisco_configuration_professional/v2_5/olh/ccp.pdf
