04-05-2017 03:13 AM - edited 03-08-2019 10:04 AM
I am able to ping the internet from the router but not able access in the client machine. Please someone tell what did I mess in the below configuration
___________________________________________________________________________________
Mafoi#sh running-config
Building configuration...
Current configuration : 1695 bytes
! Last configuration change at 21:45:30 UTC Tue Mar 2 1993
version 15.0
no service pad
hostname Mafoi
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool Mafoi
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 180.151.151.151 180.151.151.152
domain-name Mafoi
lease 7
ip cef
ip name-server 180.151.151.151
ip name-server 180.151.151.152
license udi pid CISCO861-K9 sn FGL151027AC
username bagath privilege 15 secret 5 $1$R1uY$ZkSc9mv4O3TxZvFePXsav0
interface FastEthernet0
switchport access vlan 100
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address xxx.xx.xxx.xx(wan Ip) 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan100
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 100 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 119.82.xxx.xx(Wan Gateway)
access-list 100 permit ip 192.168.1.1 0.0.0.100 any
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
04-05-2017 04:55 AM
I believe that the issue is the mask used in the access list used for NAT.
If you use the mask to represent a /24 network then I believe that it should work. I wonder why you use an extended access list when a standard access list would work and I believe would be a better solution. You are not doing anything that uses the capabilities of an extended access list that can not also be accomplished in a standard access list.
Rick
04-05-2017 11:00 PM
Hi Richards,
Thanks for the reply!
I done that too but still I'm not able use internet or ping google in the client machines.
Current config
#sh ru
Current configuration : 1643 bytes
! Last configuration change at 00:05:13 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname Mafoi
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip dhcp pool Mafoi
domain-name Mafoi
lease 7
ip cef
ip address xxx.xx.xxx.xx(wan ip) 255.255.255.252
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan100
ip nat inside
no ip http server
ip route 0.0.0.0 0.0.0.0 xxx.xx.xxx.xx(wan gateway)
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
04-06-2017 06:20 AM
When I look in the new copy of show run I do not see access list 100 configured. That would prevent NAT from working.
Rick
