Cisco 871 not routing
Paul Smith
Hi Guys,
I have configured a router to route from a Class C network to a Class A network, although I just cant get a ping from one to the other. I can see the routing table and I only want to use directly connected routes and I have not enabled any protocols. Here is my running config and my routing table, am I missing something?
Christian#sh run
Building configuration...
Current configuration : 1590 bytes
version 12.3
no service pad
hostname Christian
boot-start-marker
boot-end-marker
enable secret 5 $1$Kwwh$fbu5fbsjV8VqiKBbQ8dCP0
enable password enablepassword
username paul privilege 15 password xxx
username pauladm privilege 15 password 0 xxx
username name
no aaa new-model
ip subnet-zero
ip cef
ip name-server 192.168.2.200
ip ips po max-events 100
no ftp-server write-enable
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
switchport access vlan 2
no ip address
interface FastEthernet3
no ip address
shutdown
duplex half
speed 10
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.100 255.255.255.0
interface Vlan2
ip address 10.1.1.100 255.0.0.0
ip default-gateway 10.1.1.1
ip classless
ip http server
ip http authentication local
ip http secure-server
cdp timer 59
cdp holdtime 179
control-plane
banner exec ^CWelcome to the inner sanctum.^C
banner login ^C Please proceed if you are worthy.^C
banner motd ^CPaul's Cisco 871 Router.^C
line con 0
exec-timeout 120 20
login local
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
privilege level 15
password vtypassword
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Christian#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C    10.0.0.0/8 is directly connected, Vlan2
C    192.168.2.0/24 is directly connected, Vlan1
srikanth ath
Level 4
Level 4
Whats your setup and requirement: if you are looking for Intervlan-routing. please configure as below
no switchport access
no switch port access vlan2
no ip address
no shut
interface FastEthernet2.1
switchport mode trunk
switchport encapsulation dot1q 1  ---> where 1 is a vlan-id
interface FastEthernet2.2
switchport encapsulation dot1q 2
exit
no shut
Please rate helpful posts,
srikanth
Thanks Srikanth,
Thanks to your advice, I can now see that I need to enable vlan routing, as the Cisco 871 router does not have any layer 3 interfaces except for the 'WAN' port (FE4), which I am not using. The problem I face now is that I cant 'switchport access trunk' on my layer 2 ports (FE0 and FE2) because they will lose their IP addresses. They are both set with 'switchport access vlan' (Fe0 Vlan1 and Fe2 Vlan2). I f I switchport to trunk and then dot1q, I lose the IP addresses on the interfaces right?
johnlloyd_13
Level 9
Level 9
Kindly do the following:
871(config)vlan 2
871(config)int f0
871(config-if)switchport access vlan 1
871(config-if)switchport mode access
Plug a host on the switch port configured with the same subnet.
fb_webuser
Level 6
Level 6
if you have tried everything else then remove"ip default-gateway"
Posted by WebUser Varun Uniyal from Cisco Support Community App
