Cisco 871 routing problem
JeffDAK2408
Hi.
I have a Cisco 871 router  with this network schema
10.218.10.117 Host ---------------------10.218.10.118 FE4 || CISCO 871 || 172.18.122.5 FE0----------------------------------172.18.122.6 Host
I want the 172.18.122.6 host can do ping to the 10.218.10.117 Host at other end of the router but its not working, what is wrong with this config? could someone give me a hand?
Using 1222 out of 131072 bytes
version 12.4
no service pad
hostname ALCATE-CNT-UIO
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
enable password XXXXXXXXXXXXXXX
no aaa new-model
resource policy
ip subnet-zero
ip cef
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 10.218.10.118 255.255.255.252
speed auto
full-duplex
interface Vlan1
ip address 172.18.122.5 255.255.255.0
router rip
redistribute connected
network 10.0.0.0
network 172.18.0.0
ip classless
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Best regard
Jeff
John Blakley
Jeff,
Can each host ping their side? Do you have default gateways configured on the hosts?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
Jeff,
HTH,
John
The 172.18.120.6 Host can ping the VLAN 1 ip ( 172.18.120.5) and the FE4 ip (10.218.10.118) only, but wait, you right the 10.218.10.117 host dont have configurated the dafault gateway, let me check...
Yep, my fault, one host without default gateway set, problem solved
Thanks a lot
Thank you for letting us know
HTH,
John
