Cisco 871W - NAT/DHCP issue
armyguy298
So I purchased a Cisco 871W SOHO router for my home. I thought I had it all configured and ready to go until I connected it to my broadband modem. The issue is the WAN interface receives its IP from my ISP no problem. My wired workstation also receives an IP from my ISP and not the DHCP pool I set up. Wireless clients are receiving the correct IP from the pool. Could someone take a look at my config and see where I went wrong?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.07.02 17:02:58 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 4643 bytes
! Last configuration change at 08:43:28 EST Sat Feb 2 2013 by admin
version 15.1
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-911360573
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-911360573
revocation-check none
rsakeypair TP-self-signed-911360573
crypto pki certificate chain TP-self-signed-911360573
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 39313133 36303537 33301E17 0D313330 32303231 33343331
  365A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3931 31333630
  35373330 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  C52C05D4 083DC8B9 671E45FD DCDC64A9 8B133EC9 D2FB2049 688BB51D A73EA0CA
  270A9ADF F6C45429 18A19FEA FBB6DAA5 3F4135B5 92C858C1 E20F8DA5 46AB0513
  F4C09455 8840DEA4 C4D1FE71 849A5E66 E42222E6 90410594 81712006 E7775254
  984F4296 76758EFC FEA8BADA 8D67F418 1363C6C9 97EFE1AE 4436474D 73ABF031
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014C7 47249603 0708F01A D4ADF637 DE09A6E8 CB6DB730 1D060355
  1D0E0416 0414C747 24960307 08F01AD4 ADF637DE 09A6E8CB 6DB7300D 06092A86
  4886F70D 01010505 00038181 0035375C EFAA6E5A 964C4D00 FC8B4046 B902F128
  16409420 BB20EBA6 46773E7F D7F142F2 83EE7699 14A507A5 89596453 CCACB109
  18794B04 3A349180 D83A7DA7 206B01DA 6C17F148 AA91BA05 D6D3D2AA 2464233A
  0CEBEE81 7DB3605E 0B711CF4 0E9CD1E1 BA15F715 F3DA2FE4 5C85E87C 282C3C6C
  2D70C2E4 F276CA6A 19834618 82
      quit
dot11 syslog
dot11 ssid [my ssid]
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 094E5B001A0E100712
ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.49
ip dhcp pool DHCP-POOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
ip cef
no ip domain lookup
no ipv6 cef
username admin privilege 15 secret 4 Q3ixttsveGEmBIULtVu7zqaBEoCuhrE8Ko.6zJO0wok
bridge irb
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip nat outside
ip virtual-reassembly in
interface FastEthernet0
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description WAN-CONNECTION
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
bridge-group 1
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
ssid [my ssid]
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
rts threshold 2312
interface Dot11Radio0.1
description Wireless VLAN 1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description INTERNAL-NETWORK
ip nat inside
bridge-group 1
interface BVI1
description INTERNAL BRIDGE WIRED-TO-WIRELESS
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
exec-timeout 5 0
login local
no modem enable
transport output all
line aux 0
exec-timeout 5 0
login local
transport input telnet ssh
line vty 0 4
exec-timeout 5 0
privilege level 15
login local
end
kcnajaf
Level 7
Level 7
Hi Brian,
I don't think you need any bridge group configuration under your WAN interface. Try taking that out as below and check
no bridge-group 1
Also which port you are using to connect the wired client?
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
Hi Brian,
no bridge-group 1
Najaf
Thanks Najaf! I will give that a try tonight.
I was connecting my workstation into FastEthernet1.
I will report back when I know more.
Brian
For persons who are new to the Cisco 871W, I will post my configuration here. When I bought this router, I was tired of the same crappy consumer grade routers dieing on me all the time. Since this router has been online, I have had zero issues. Thanks Najaf for yor help! This configuration has a basic firewall setup, some crypto to implement a VPN at a later date, and WPA2 security for 802.11g. GOOD LUCK!
Current configuration : 7944 bytes
! Last configuration change at 15:15:06 EST Sat Jan 25 2014 by admin
! NVRAM config last updated at 15:15:07 EST Sat Jan 25 2014 by admin
version 15.1
no service pad
hostname HOSTNAME OF YOUR ROUTER
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
      quit
dot11 syslog
dot11 ssid YOUR SSID NAME
vlan 1
authentication open
guest-mode
mbssid guest-mode
wpa-psk ascii YOUR WIRELESS PASSWORD
ip source-route
lease 30
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
username admin privilege 15 secret YOUR ROUTER MANAGEMENT PASSWORD
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  drop
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
bridge irb
interface Loopback0
description $FW_INSIDE$
ip nat outside
zone-member security in-zone
no ip address
no ip address
no ip address
no ip address
description WAN-CONNECTION$FW_OUTSIDE$
ip address dhcp
ip nat outside
zone-member security out-zone
duplex auto
speed auto
no cdp enable
no ip address
broadcast-key vlan 1 change 30
ssid YOUR WIRELESS SSID
mbssid
channel 2437 YOUR 802.11g FREQUENCY (2437 IS CHANNEL 6)
station-role root
rts threshold 2312
description WIRELESS VLAN 1
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip http server
ip route 0.0.0.0 0.0.0.0 dhcp
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
control-plane
bridge 1 route ip
line con 0
exec-timeout 5 0
login local
no modem enable
line aux 0
exec-timeout 5 0
login local
line vty 0 4
exec-timeout 5 0
privilege level 15
login local
ntp server 3.north-america.pool.ntp.org
ntp server 1.north-america.pool.ntp.org
ntp server 0.north-america.pool.ntp.org prefer
ntp server 2.north-america.pool.ntp.org
end
