Cisco 871W port mapping not working
cchipont
I am managing Cisco 871W Integrated Services Router.
I'm noob to cisco ios but have strong linux and programming basis, so I've been able with som ehelp to manage and configure the router.
But, now I have to open port 3307 in the router and map it to the 192.168.1.88 ip in the lan and don't understand what is the problem as I can't get it to work. All other ports I've mapped (22, 143, etc.) are in perfect order.
Here is a copy of my running-config and any help willl be really welcome
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$0uVc$XXhnKvo1eBB9dK80rYv8W0
no aaa new-model
clock timezone PCTime -3
crypto pki trustpoint TP-self-signed-1384173472
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1384173472
revocation-check none
rsakeypair TP-self-signed-1384173472
crypto pki certificate chain TP-self-signed-1384173472
certificate self-signed 01
  3082024B 308201B4 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31333834 31373334 3732301E 170D3032 30333031 30303038
  32325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 33383431
  37333437 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D014 4650F7F6 D7B8C139 EF5E4136 3B1B97BB 7CF7E730 5C4B8601 B6CD6B59
  DBCFA5A9 88AB7F7A FE082F62 0ECAFA92 D590D2AD BCA775C6 6EBFF2AE D41D7166
  C77059C5 49798B20 4491A19C C0BBE9B0 C9788E13 FD61D02A 355A06A5 606EDD57
  3738F5C5 26661274 BEA86468 F585BE11 D5325B36 480E0436 C6EF6F86 0DA21587
  0A010203 010001A3 73307130 0F060355 1D130101 FF040530 030101FF 301E0603
  551D1104 17301582 13636973 636F2E64 6F756572 2E6D696E 652E6E75 301F0603
  551D2304 18301680 1468D064 234801DB FEF14CB1 BBAB674C D3D1CECA 28301D06
  03551D0E 04160414 68D06423 4801DBFE F14CB1BB AB674CD3 D1CECA28 300D0609
  2A864886 F70D0101 04050003 81810060 65955928 793A4BBA C04B83EB 2D803284
  6F5016AE 0AE544F4 1C6EE79E CF3739FF 69B672B9 06FCF11E A17EEE5A 0165FF8E
  1F896997 AABC4BBB 7C938634 B78D8469 3C4D0FDF 5EB6FF48 CFC6EAAA 8D30636A
  A6571AE9 DC9498BB 5FB8FFE8 20D866C3 5A9C3A04 9565B394 5A376C4B A9B7FC75
  55CC1662 DCEF63CB C22C5463 F3A8DE
            quit
dot11 syslog
dot11 ssid douer_main
   authentication open
   guest-mode
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool sdm-pool1
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 192.168.1.88 208.67.222.222 208.67.222.220
ip port-map user-protocol--2 port tcp 10000
ip port-map user-protocol--1 port tcp 5729
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip bootp server
ip domain name douer.mine.nu
ip host douer.mine.nu 192.168.1.88
ip name-server 192.168.1.88
ip name-server 208.67.222.222
ip name-server 208.67.222.220
username admin privilege 15 secret 5 $1$ujZJ$3Gcyq1RbCmpEukHSxTW1j0
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip scp server enable
class-map type inspect match-all sdm-nat-http-1
match access-group 102
match protocol http
class-map type inspect match-all sdm-nat-user-protocol--2-1
match access-group 105
match protocol user-protocol--2
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 104
match protocol user-protocol--1
class-map type inspect match-all sdm-nat-imap-1
match access-group 103
match protocol imap
class-map type inspect match-any sdm-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-insp-traffic
match class-map sdm-cls-insp-traffic
class-map type inspect match-any sdm-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-invalid-src
match access-group 100
class-map type inspect match-all sdm-icmp-access
match class-map sdm-cls-icmp-access
class-map type inspect match-all sdm-protocol-http
match protocol http
class-map type inspect match-all sdm-nat-ssh-1
match access-group 101
match protocol ssh
policy-map type inspect sdm-permit-icmpreply
class type inspect sdm-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-ssh-1
  inspect
class type inspect sdm-nat-http-1
  inspect
class type inspect sdm-nat-imap-1
  inspect
class type inspect sdm-nat-user-protocol--1-1
  inspect
class type inspect sdm-nat-user-protocol--2-1
  inspect
class class-default
policy-map type inspect sdm-inspect
class type inspect sdm-invalid-src
  drop log
class type inspect sdm-insp-traffic
  inspect
class type inspect sdm-protocol-http
  inspect
class class-default
class class-default
zone security out-zone
zone security in-zone
zone-pair security sdm-zp-self-out source self destination out-zone
service-policy type inspect sdm-permit-icmpreply
zone-pair security sdm-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-out source in-zone destination out-zone
service-policy type inspect sdm-inspect
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
zone-member security out-zone
ip route-cache flow
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption key 1 size 40bit 7 0F72F0FD678D transmit-key
encryption mode wep mandatory
ssid douer_main
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1412
ip forward-protocol nd
ip http server
ip http port 8080
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.88 22 interface FastEthernet4 22
ip nat inside source static tcp 192.168.1.88 143 interface FastEthernet4 143
ip nat inside source static tcp 192.168.1.88 5729 interface FastEthernet4 5729
ip nat inside source static tcp 192.168.1.88 10000 interface FastEthernet4 10000
ip nat inside source static tcp 192.168.1.88 80 interface FastEthernet4 80
ip nat inside source static tcp 192.168.1.88 3307 interface FastEthernet4 3307
logging trap debugging
logging facility local2
logging 192.168.1.88
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit any
access-list 100 remark SDM_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark SDM_ACL Category=0
access-list 101 permit ip any host 192.168.1.88
access-list 101 permit tcp any host 192.168.1.88 eq www
access-list 102 remark SDM_ACL Category=0
access-list 102 permit ip any host 192.168.1.88
access-list 103 remark SDM_ACL Category=0
access-list 103 permit ip any host 192.168.1.88
access-list 104 remark SDM_ACL Category=0
access-list 104 permit ip any host 192.168.1.88
access-list 105 remark SDM_ACL Category=0
access-list 105 permit ip any host 192.168.1.88
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner exec
% Password expiration warning.
Cisco Router and Security Device Manager (SDM) is installed on this device and
it provides the default username "cisco" for  one-time use. If you have already
used the username "cisco" to login to the router and your IOS image supports the
"one-time" user option, then this username has already expired. You will not be
able to login to the router with this username after you exit this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
banner login  Authorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
if Anyone could help I'd reall appreciate it.
Hi Christian,
Try to temporarily disable these commands and try again.
Further check the settings on the 192.168.1.88 as per Naidu.
9 Replies 9
johnlloyd_13
Level 9
Level 9
Hi Christian,
Could you try adding the below and test again!
ip nat inside source static udp 192.168.1.88 3307 interface FastEthernet4 3307
Thanks for your kind help, I've tried, but doesn't seem to work.
I'm not shure whats happening, but all other open ports work, could it be something in policies or acl?
Do you know how I could drop the firewall to test if the firewall is the problem?
Try to turn off the firewall in 192.168.1.88 and check.
see the below link to know how to turn off the windows firewal..
http://support.microsoft.com/kb/283673
Please rate the helpfull posts.
Naidu.
The 192.168.1.88 has not a firewall and it is not a windows server.
Hi Christian,
Dear John,
Thanks for your kind help. What would be the command to disable this?
192.168.1.88 is not running windows, is centos, and it has no firewall up right now.
Christian
just issue each command under the corresponding interfaces:
int f4
no zone-member security out-zone
int bvi1
no zone-member security in-zone
Regards.
Alain.
ok, finally solved it.
What I did whas using the sdm instead of punching in manual commands. Seems it had something to do with ACL and protocols.
Thanks for all your help.
Christian
Hi Christian,
Thanks for the feedback and glad your problem is now resolved! Just curious, could we know what you did on your ACL that made it worked?
As a side note and IMHO, CLI is still the best approach when it comes to troubleshooting.
