cisco 877 add ip address fe1
Alex801415
Hi all!
I have a 877 cisco router.
I want to put 2 ip addresses on this router.
This addresses are in different networks and differents vlan untagged.
I want to use port fastethernet0 and fastethernet1 to connect the router to another switch router.
My switch did vlan by port.
I use switchport access for the first vlan and I can put the IP on the FE0.
But when I try to put the second vlan and second IP I can't add a new vlan because the router is blocked for 2 vlan and first vlan is not deletable.
When I try to put directly the ip to interface I issue an error message.
How can I put 2 ip from diffrents network on my router (on two differents physical ports) in order to communicate with my other switch router?
Alex
Kostas Kyriakos
Hello.
The 4 FastEthernet ports you see at the back of your Cisco 877 are not L3 ports. In other words you cannot configure an IP address directly on them. You have to use VLANs for that matter. Use the following as a recommendation because it is not very clear what you are trying to achieve:
View Configured VLANs:
Router#show vlan-switch
Add VLAN:
Router#vlan database
Router(vlan)#vlan 2 name FIRST-TWO-SWITCHPORTS
Router(vlan)#vlan 3 name LAST-TWO-SWITCHPORTS
Router(vlan)#exit
Remove VLAN:
Router(vlan)#no vlan 2
Router(vlan)#exit
Assign Switchport(s) to Existing VLAN:
Interface FastEthernet0/0
switchport access vlan 2
Interface FastEthernet0/1
Interface FastEthernet0/2
switchport access vlan 3
Interface FastEthernet0/3
Assign IP address to VLAN:
Interface Vlan2
ip address 1.1.1.1 255.255.255.0
Hope this helps.
