Cisco 877 and Enet Encap
olyapovgrrc
Hello! How to configure 877 router with enet encapsulation? Multiplexing LLC-based.
My config does not work, can you tell please, what's wrong:
2 Accepted Solutions
John Blakley
What is your config supposed to reference? Are you connecting to a DSL provider? What type of connection is this? Did they assign you the IP address? Do you have some other device that is connecting to the router on the provider-facing side?
The config doesn't look complete, but it's hard to tell you what's missing without knowing what you're connecting to.
HTH,
John
HTH, John *** Please rate all useful posts ***
Giuseppe Larosa
Hello
use the following document
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e5f.shtml#configs
to implement IRB correctly you need also:
bridge ip protocol ieee
bridge 1 route ip
also to make a bridge also the lan interfaces or the Vlan1 needs to be associated to bridge-group 1.
But to be noted if you do so NAT is not needed or possible.
So you need to think about what you want to achieve
Hope to help
Giuseppe
John Blakley
HTH,
John
Giuseppe Larosa
Hello
bridge 1 route ip
Hope to help
Giuseppe
Thank you very much! It was helpful.
