Cisco 877 and Vlans :)
GuyCisco
Good Day Everyone
We are building a network on a budget and managed to get 3 Cisco 877 ADSL routers for 50 bucks a piece. What a bargain!
I have a little question though.
According to the documentation on these routers they "Should Support"up to 4 VLANs. Which is fine, you can add a network on each LAN port. This way you can work around not being able to assign virtual interfaces or being able to assign ip addresses to each individual port.
All 3 of my bargain/bin Cisco 877 routers though seem to be limited to only the default + 1 additional VLAN... Bummer seems like these are meant for REALLY small SOHO networks...
Is there a way i can work around this limitation?
Or is there a specific version of IOS i need to load to support up to 4 VLANs?
The memory on all 3 routers seems to be limited to files up to 21mb so so the highest version of IOS I have been able to go was 12.4.24 Advanced IP Services or 15.1.4 advanced security. Currently running 12.4.24 AIS.
Kind Regards
Willie Pretorius
2 Accepted Solutions
Leo Laohoo
870 supports up to 4 VLANs ... if it's loaded with IOS version 12.4 (and later).
Downgrade the IOS to 12.3 and 10 VLANs are supported.
I think you need Advanced IP Services to run multiple VLANs...
How much memory do you have ? Post the output of 'show version'...
18 Replies 18
Leo Laohoo
Unfortunately it doesn't work for me. Here i have two of my routers
one i just upgraded to IOS package c870-adventerprisek9-mz.123-8.yi3.bin
Another one on  c870-advsecurityk9-mz.124-24.T1.bin
Both of these IOS versions only allow me to add 2x vlans.
Is this maybe something stuck in the NVRAM limiting my vlans?
Pixel_R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Pixel_R1(config)#vlan 30
Vlan can not be added. Maximum number of 2 vlan(s) in the database.
Pixel_R1(config)#exit
Pixel_R1#sh vber
*Mar 1 11:06:07.135: %SYS-5-CONFIG_I: Configured from console by console
Pixel_R1#sh flash:
24576K bytes of processor board System flash (Intel Strataflash)
Directory of flash:/
2 -rwx 12707144 Mar 1 2002 10:50:45 +00:00 c870-adventerprisek9-mz.123-8.yi3.bin
3 -rwx 3331 Mar 1 2002 00:03:51 +00:00 cpconfig-8xx.cfg
4 -rwx 660 Mar 1 2002 09:18:02 +00:00 vlan.dat
5 -rwx 1038 Mar 1 2002 00:04:27 +00:00 home.shtml
6 -rwx 115712 Mar 1 2002 00:04:35 +00:00 home.tar
7 -rwx 527849 Mar 1 2002 00:04:48 +00:00 128MB.sdf
23482368 bytes total (10117120 bytes free)
Pixel_R1#
Pixel_R2#sh flash:
2 -rwx 18794308 --- -- ---- --:--:-- ----- c870-advsecurityk9-mz.124-24.T1
3 -rwx 660 Mar 1 2002 01:56:27 +00:00 vlan.dat
23482368 bytes total (4681728 bytes free)
Pixel_R2#conf t
Pixel_R2(config)#vlan 30
Pixel_R2(config)#
Kind Regards
Willie pretorius
 Here is my sh version if it helps.
Router#sh ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI2, RELEASE SOFTWARE (fc1)
Synched to technology version 12.3(10.3)T2
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 14-Jun-05 18:58 by ealyon
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
ROM: Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI2, RELEASE SOFTWARE (fc1)
Router uptime is 5 minutes
System returned to ROM by reload
System image file is "flash:c870-advipservicesk9-mz.123-8.YI2.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 877 (MPC8272) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FCZ141393GM
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
Router#sh ver
export@cisco.com.
1 ATM interface
Referring to your post here. I think you are getting 10 Vlans because you were using a different model router the Cisco 871W (MPC8272) processor (revision 0x200) with 118784K/12288K.
I cant really say for certain since all of the 800 series routers share the same feature sheet.
http://www.maxitelonline.com/productos/descarga/Cisco%20870%20-%20Q&A.pdf
I've tested this router and it can support 10 VLANs if loaded with 12.3 (HERE).
You're trying to create more than 2 VLANs running 12.4.  This won't work.
Good Evening
I swopped to using c870-advipservicesk9-mz.123-8.YI2.bin
But it doesnt seem to support vlans at all. I have a version of 12.3-14 thats a bit older that im going to try next then move back to 12.4 and try adv ip services
Router#conf t
Router(config)#vlan 20
% Invalid input detected at '^' marker.
Router(config)#vlan ac
Router(config)#vlan accounting
Router(config)#
I will try the advanced ip services tonight and post back thanks.
try the 'vlan database' exec command:
877#vlan database
Am i doing something wrong? c870-advipservicesk9-mz.123-14.YT1.bin also wont allow me to add vlans...
2 -rwx 13729692 Mar 01 2002 08:42:46 +00:00 c870-advipservicesk9-mz.123-14.YT1.bin
3 -rwx 3331 Mar 01 2002 00:03:51 +00:00 cpconfig-8xx.cfg
5 -rwx 1038 Mar 01 2002 00:04:27 +00:00 home.shtml
6 -rwx 115712 Mar 01 2002 00:04:35 +00:00 home.tar
7 -rwx 527849 Mar 01 2002 00:04:48 +00:00 128MB.sdf
23482368 bytes total (9097216 bytes free)
Router(config)#vlan 10
There should be a vlan.dat file in your flash. What do you get with the 'vlan database' exec command ?
If it helps here it is.
Router#vlan database
% Warning: It is recommended to configure VLAN from config mode,
as VLAN database mode is being deprecated. Please consult user
documentation for configuring VTP/VLAN in config mode.
Router(vlan)#?
VLAN database editing buffer manipulation commands:
abort Exit mode without applying the changes
apply Apply current changes and bump revision number
exit Apply changes, bump revision number, and exit mode
no Negate a command or set its defaults
reset Abandon current changes and reread current database
show Show database information
vlan Add, delete, or modify values associated with a single VLAN
vtp Perform VTP administrative functions.
Router(vlan)#show
VLAN ISL Id: 1
Media Type: Ethernet
VLAN 802.10 Id: 100001
State: Operational
MTU: 1500
Translational Bridged VLAN: 1002
Translational Bridged VLAN: 1003
VLAN ISL Id: 20
VLAN 802.10 Id: 100020
State: Operational
MTU: 1500
VLAN ISL Id: 1002
Media Type: FDDI
VLAN 802.10 Id: 101002
State: Operational
MTU: 1500
Bridge Type: SRB
VLAN ISL Id: 1003
Media Type: Token Ring
VLAN 802.10 Id: 101003
State: Operational
MTU: 1500
Bridge Type: SRB
Ring Number: 0
Bridge Number: 1
Parent VLAN: 1005
Maximum ARE Hop Count: 7
Maximum STE Hop Count: 7
Backup CRF Mode: Disabled
VLAN ISL Id: 1004
Media Type: FDDI Net
VLAN 802.10 Id: 101004
State: Operational
MTU: 1500
Bridge Type: SRB
Bridge Number: 1
STP Type: IBM
VLAN ISL Id: 1005
Media Type: Token Ring Net
VLAN 802.10 Id: 101005
State: Operational
MTU: 1500
Bridge Type: SRB
Bridge Number: 1
STP Type: IBM
Router(vlan)# no vtp
Router(vlan)# no vtp ?
client Set the device to client mode.
password Set the password for the VTP administrative domain.
pruning Set the administrative domain to permit pruning.
transparent Set the device to transparent mode.
v2-mode Set the administrative domain to V2 mode.
Router(vlan)# no vtp pru
Router(vlan)# no vtp pruning
Pruning already switched off.
Router(vlan)#no vtp cli
Router(vlan)#no vtp client
Device mode not VTP CLIENT.
Router(vlan)#no vtp
Router(vlan)#no vtp ?
Router(vlan)#exit
APPLY completed.
So can you add your VLANs here ?
E.g.:
Router(vlan)#vlan 30
E.g.:
Yes Georg however im still limited to 2 vlans, I reinstalled the Advanced security firmware124.23 though as advanced ip services 123.8 and .14 wont even give me the command for vlan database or to add vlans.
I will keep looking for a version of advanced ip services 124 that will give me 4x vlans. there is only 2 versions of 123 available as far as i can see.
Kind Regards
Willie Pretorius
