Cisco 877 defaults to Rommon mode when switched on.
whiteford
I have a Cisco 877 that when ever it is switched on it will default to rommon mode, if I type reset it will boot up the IOS and startup/running config.
Show version displays the congiguration register as 0x2102
The ISO is c870-advsecurityk9-mz.124-15.T7.bin
fsebera
Level 4
Level 4
Perhaps a "show diag" will reveal some issues.
Instead of reset, try i and record what happens - this may/may not reveal more details.
Other than that - Perhaps a TAC case.
Frank
Here it is:
sh diag
C877 Mainboard
Motherboard is analyzed
Motherboard insertion time unknown
EEPROM contents at hardware discovery:
Chassis MAC Address : 0023.02f8.9d2a
MAC Address block size : 10
PCB Serial Number : FOC12352UGG
Hardware Revision : 3.0
Part Number : 74-3501-05
Board Revision : C1
Top Assy. Part Number : 800-26784-06
Deviation Number : 0
Fab Version : 03
CLEI Code : VAMG510DRB
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : CISCO877-K9
Version Identifier : V05
Processor type : 94
Chassis Serial Number : FCZ123911L6
Radio Country Code : FFFF
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C3 06 00 23 04 F8 9D 3A 43 00 0A C1 8B 46
0x10: 4F 43 31 32 33 35 32 55 47 47 40 04 B5 41 03 00
0x20: 82 4A 0D AD 05 42 43 31 C0 46 03 20 00 68 A0 06
0x30: 88 00 00 00 00 02 03 C6 8A 56 41 4D 47 35 31 30
0x40: 44 52 42 03 00 81 00 00 00 00 04 00 CB 94 43 49
0x50: 53 43 4F 38 37 37 2D 4B 39 20 20 20 20 20 20 20
0x60: 20 20 89 56 30 35 20 D9 02 40 C1 09 94 C2 8B 46
0x70: 43 5A 31 32 33 39 31 31 4C 36 4A FF FF FF FF
Power Over Ethernet Module : Not Detected
sh version
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 14-Aug-08 07:43 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Dublin-WH-877 uptime is 3 minutes
System image file is "flash:c870-advsecurityk9-mz.124-15.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 877 (MPC8272) processor (revision 0x300) with 118784K/12288K bytes of memory.
Processor board ID FCZ123911L6
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
Leo Laohoo
Hi Andy,
What is your flash and DRAM memory size of your appliance?
We had an experience where the IOS of the 877 would randomly gets corrupted. After a few headslapping events, it was boiled down to not reading the instructions. Our 877 has 24mb of flash but in the download page (which everyone, including me, took for granted), the flash required was 28 mb.
Hope this helps.
Leo Laohoo
I'd recommend you upgrade to 12.4.15T9. Your current version has a long list of bugs that looks like a chinese takeaway menu.
