Cisco 877 - NAT and Port forwarding with 6 Static IP
a.portesi
I've 8 Static IP assigned me from my ISP.
  • x.y.w.56 (not usable)
  • x.y.w.57
  • x.y.w.58
  • x.y.w.59
  • x.y.w.60
  • x.y.w.61
  • x.y.w.62
  • x.y.w.63 (no usable)
Subnet 255.255.255.248
I've a 877 Router and I would to:
  • NAT al LAN Client with x.y.w.57
  • Configure some ports ( i.e. 80 and 443) to be forewarded from x.y.w.57 to one LAN Server ( i.e. 192.168.0.1)
  • Configure some ports ( i.e. 443) to be forewarded from x.y.w.58 to another LAN Server ( i.e. 192.168.0.2)
It is possible?
How?
cadet alain
yes it is possible.
1) NAT client:  ip nat inside source list 1 pool mypool overload
                          ip nat pool mypool x.y.w.57 x.y.w.57 prefix-length 29
                          access-list 1 permit host
2) for the port forwarding:
  ip nat inside source static tcp 192.168.0.1 80  x.y.w.57 80 extendable
  ip nat inside source static tcp 192.168.0.1 443  x.y.w.57 443 extendable
  ip nat inside source static tcp 192.168.0.2 80  x.y.w.58 443 extendable
configure your interfaces for nat with ip nat inside and ip nat outside.
Regards.
Alain
Hi Alain,
     i'm having troubles somewhere but don't know where...
     can you post a sample for a solution like this?
     thank you in advance
post your config and  explain what problems you have.
Regards.
Alain
