Cisco 877 Router ios problem
umitinternet
Hello everyone,
I erased flash of my 877 router so ios.
my problem is I cant install ios again, i try to send ios image via xmodem but its not work.
can anyone help me?
regards & thans
Reza Sharifi
Try using tftpnld.  If you want to use Xmodem and it is not working with your current client than try a different client like Putty (it is free).  If you can use tftpnld, it is a lot faster.
Follow this link:
http://www.cisco.com/en/US/docs/routers/access/800/801/software/configuration/guide/rommon.html#wp1020643
first, thank you very much for your reply.
actually I installed ios on dram but I couldnt install it on flash so when I turn off it everything erases. my question: How can I save it from dram to flash? Thanks a lot...
