Cisco 877W - Config ATM0 and ATM0.1 help needed please
TRVA_ADMIN
Can anyone advise me how to get the following config lines into the one below it?
I am not familiar with such settings, but I know this is what I need to add to my 877W config. All other settings are the same for both config.txt files.
Required config lines:
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
   dsl operating-mode auto
interface ATM0.1 point-to-point
description $FW_OUTSIDE$$ES_WAN$
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
     shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 217.39.180.189 255.255.255.248
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
       ip inspect SDM_LOW out
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname ??????.com
ppp chap password 7 ????????
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 2 interface Dialer0 overload
logging trap debugging
access-list 1 remark SDM_ACL Category=2
         access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 217.39.180.184 0.0.0.7
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 10.0.0.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp host 213.120.62.101 eq domain any
access-list 101 permit udp host 213.120.62.97 eq domain any
access-list 101 deny   ip 217.39.180.184 0.0.0.7 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip host 0.0.0.0 any
access-list 101 deny   ip any any log
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 217.39.180.184 0.0.0.7 any
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any unreachable
access-list 102 deny   ip 172.16.0.0 0.15.255.255 any
access-list 102 deny   ip 192.168.0.0 0.0.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip host 0.0.0.0 any
access-list 102 deny   ip any any log
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp host 213.120.62.101 eq domain any
access-list 103 permit udp host 213.120.62.97 eq domain any
access-list 103 deny   ip 217.39.180.184 0.0.0.7 any
access-list 103 permit icmp any any echo-reply
access-list 103 permit icmp any any time-exceeded
access-list 103 permit icmp any any unreachable
access-list 103 deny   ip 10.0.0.0 0.255.255.255 any
access-list 103 deny   ip 172.16.0.0 0.15.255.255 any
          access-list 103 deny   ip 192.168.0.0 0.0.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip host 0.0.0.0 any
access-list 103 deny   ip any any log
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
     transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Router#
Actual current config lines:
interface ATM0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
no ip address
shutdown
station-role root
interface Vlan1
no ip address
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
router#
cadet alain
just go into config mode and copy paste the lines then save the running-config with the wr command ONCE you're sure everything is ok.
Regards.
Alain
cadet alain
Regards.
Alain
Thanks - that worked. One thing I noticed, was that if I tried to change all the configuration lines in one go, the transfer failed. I did not have this problem if I cut and pasted several lines at a time, and then did "transfer to host" using HyperTerminal.
I checked my HyperTerminal settings and they all look correct, so I'm not sure why I would have this issue.
Hyperterm is poor software, use Putty or equivalent.
