cisco 878 config problem
ahmed-aftab
we have a small bracnch and have cisco 878
i configured svi but host are still unable to access internet
given below is the config for your kind review
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$uiYN$LFoF7dtH2wm8haGjFIXRO/
no aaa new-model
resource policy
ip cef
username scg privilege 15 secret 5 $1$n1xQ$Rlf9XVA67WZ5lxPKPyUo90
controller DSL 0
line-term cpe
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key xxxxxxxxx!
crypto ipsec transform-set TSET esp-3des esp-md5-hmac
crypto dynamic-map DMAP 1000
set transforSET
set pfs group2
match address 100
crypto dynamic-map vpn 20
set pfs group5
match address 100
crypto map SMAP 10 ipsec-isakmp dynamic DMAP
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
switchport access vlan 20
interface FastEthernet2
switchport access vlan 30
interface FastEthernet3
interface Vlan1
no ip address
interface Vlan10
ip address 94.x.x.x 255.255.255.248                (public ip)
crypto map SMAP
interface Vlan20
ip address 192.168.0.1 255.255.255.0
interface Vlan30
ip address 10.1.1.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 94.200.103.73
no ip http server
no ip http secure-server
no ip http server
access-list 100 permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
scheduler max-task-time 5000
regards
Aftab Ahmed
interface vlan 30
ip nat outside
Get rid of the ip nat outside here it has no meaning here.
Can you ping and at the same time post output of sh ip nat translation and also do a debug ip packet 101 where 101 is following acl: access-list 101 permit icmp any any.
Regards.
Alain.
6 Replies 6
cadet alain
Could you also post what you tried to communicate: from which IP to which IP and which protocol and post the result output.
Regards.
Alain.
hello 1
just want to access to internet but nops
the user form
192.168.0.0/24
and user
10.1.1.0/24 are not able to access internet
thanks and regards
Aftab Ahmed
you have to configure NAT overload:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic3
Regards.
alain.
applied the following config but results are same
access-list 100 permit ip any any
ip nat inside source list 100 interface vlan 10 overload
interface vlan 10
ip nat outside
interface vlan 20
ip nat inside
interface vlan 30
ip nat outside
thank & regards
Aftab Ahmed
interface vlan 30
ip nat outside
Regards.
Alain.
thank you alain its done
