cisco 881 configuration
kingelka23
Hi l have two network the head office (site A : 192.168.1.0 ) and a small branch with 10 hosts (site B : 192.168.1.0).
i need to grant access to site A ressources, so we decide to buy a CISCO 881 for this remote office.
As you can see below  the Wan interface is configured with ip adress (192.168.1.1 )
The local VLAN have 192.168.2.1 address.
After a telnet on the remote CISCO 881 l can ping all my servers on 192.168.1.0 /24 network.
But when l connect a computer (we can call pc1)  to one of the fastethernet port (0 to 3) l can't ping the remote servers on site A ( but the router can )
Finally after waiting few minutes, the computer (pc1 : 192.168.2.10) can finally reach 192.168.1.0/24 hosts. when a second pc (pc 2 :192.168.2.20 ) is connected , the same issue came : pc2 can just reach the router WAN interface ( 192.168.1.1 ) but we can't ping servers on remote network ( 192.168.1.0 )
without any solution l tried this : l change pc2 IP address and give it pc1 address and also connected it to the same port as pc1
after these changes l can now ping remote ressources on 192.168.1.0/24 but pc1 can't now.
That's my first experience with 800 series router.
On site B l have 6 hosts and what l was trying to do is : connect all my hosts to a simple switch with 8 ethernet ports,  and rely another port of this switch to one of my CISCO 881 fastethernet port ( which belong to VLAN1 by default ). But what l describe before is when the 2 pc are directly connect to  cisco 881 switcports.
Please see my configuration below and tell me about your experience with this material (881)
did i miss something on my configuration or Cisco 881 have any particularity that l don't know ?
Thanks a lot for your assistance
Current configuration : 3046 bytes
version 15.2
no service pad
service password-encryption
hostname Routeur_K
boot-start-marker
boot-end-marker
enable password 7 11291D081E1C2925260F
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1752650953
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1752650953
revocation-check none
rsakeypair TP-self-signed-1752650953
crypto pki certificate chain TP-self-signed-1752650953
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31373532 36353039 3533301E 170D3133 30363231 31393435
  34325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37353236
  35303935 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B327 740AE8E1 0EC120E8 7280CC27 CD82DB34 37899D01 C833600F 70F9013F
  C4FA2730 1967D109 61E454E8 E29B155C 53383907 01CA3894 3E0E36BD CB6A6F5A
  DB44B699 765C8312 63033DBD 167B97C0 FA25C9FE C94D8515 7AB8E738 FA78321E
  6C81E1C9 4D3A81A8 D2068751 3E47A1D2 E6CDA1C7 3B272294 8664E321 AB7D18C9
  3DDD0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14AA0EF9 8E9086C0 318DC6F1 CC99C9D3 5625CEB9 67301D06
  03551D0E 04160414 AA0EF98E 9086C031 8DC6F1CC 99C9D356 25CEB967 300D0609
  2A864886 F70D0101 05050003 81810075 2A64F629 3FE77867 CBB73C35 B93C0216
  0B594EEF F096BC12 CFC2DC8B 6D1ABB3C 3FFBB024 704082FA EC766AA1 04837B90
  A9566877 855BDB3D EC134AFE E8BAD330 C50D1078 316B7D64 99776507 17C4CDCC
  FCBB8837 11D61371 8DEAE186 B781BAA1 2F5F2F35 C3AC9E9B CDE494D1 5801E89E
  32429237 2382100F 25DF852F CE4C36
        quit
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 192.168.2.1
ip name-server 81.91.236.71
ip name-server 81.91.236.72
ip cef
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FCZ1704C032
username FGCHSJK privilege 15 secret 4 /tX7S/B5iugv6vHRfWliaJnnb0lDLhN410OAwRQa3ZQ
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description Wan
ip address 192.168.1.10 255.255.255.0
duplex auto
speed auto
interface Vlan1
description Lan_Agence
ip address 192.168.2.1 255.255.255.0
no autostate
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip route 192.168.1.0 255.255.255.0 192.168.1.100 permanent
ip route 192.168.2.0 255.255.255.0 Vlan1 permanent
access-list 1 permit any
control-plane
line con 0
line aux 0
line vty 0 4
session-timeout 120
login
transport input all
end
acampbell
Can you try ammending both your DHCP scope and your static routing table
conf t
ip dhcp pool DATA-VLAN-1
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 81.91.236.71 81.91.236.72
   domain-name YOURDOMAIN.com
no ip route 192.168.1.0 255.255.255.0 192.168.1.100 permanent
no ip route 192.168.2.0 255.255.255.0 Vlan1 permanent
ip router 0.0.0.0 0.0.0.0 192.168.1.100 name DEFAULT-ROUTE
end
then Retest
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi Acampbell
Thanks for your reply
Let's me try and send you the feedback
Hi acampbell
i have made all changes you suggest and please see below my new config
Current configuration : 5759 bytes
! Last configuration change at 19:56:14 PCTime Mon Jan 2 2006 by XXXXX
! NVRAM config last updated at 19:56:29 PCTime Mon Jan 2 2006 by XXXXX
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
hostname Routeur_K
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 4 /tX7S/B5iugv6vHRfWliaJnnb0lDLhN410OAwRQa3ZQ
no aaa new-model
clock timezone PCTime 1 0
crypto pki trustpoint TP-self-signed-4031057318
subject-name cn=IOS-Self-Signed-Certificate-4031057318
rsakeypair TP-self-signed-4031057318
crypto pki certificate chain TP-self-signed-4031057318
  69666963 6174652D 34303331 30353733 3138301E 170D3036 30313032 31323030
  34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30333130
  35373331 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100AF8B 2C34EA76 5BA7E102 A3A60B70 7B7725E6 C77ACF89 774A672F 308897DC
  79EB24B8 EAB888F8 5642A0BA 0647F1A2 7AF64F94 5DE7C6AE 7457B569 B67BF3BD
  B8AC6E5E 1F3D6177 7CAC4C8F 98D8263B DD49B8A4 54E990DA 2102484E 763F7FA7
  D5E8625D EF97F98A A0744912 41524C7A 31B16AB4 666E3ECE 332DCBE6 C5F983DA
  572F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1436F048 E4D8C5B6 934A9612 CB92B4D7 E34FA423 F5301D06
  03551D0E 04160414 36F048E4 D8C5B693 4A9612CB 92B4D7E3 4FA423F5 300D0609
  2A864886 F70D0101 05050003 81810088 85CC53EE FD8FF7DA 6E2C5A31 5D49D7F7
  AAE7F092 9DCD6B4B 7C80E56F 22F8DFEC 439B9C66 56101924 58CDDA36 36B3F5A5
  6535A243 B1C53857 9E947974 755826D0 EC386570 98D8904D AD2AD04D 4FB420AD
  6CB62A06 B06D2854 6DE2355B 73696848 AE6415D9 1BF0FE03 01D0AB8C E5CD0812
  D0122D06 3EF2B27D 9F13F761 13EA96
        quit
no ip source-route
ip dhcp pool ccp-pool
domain-name TEST.COM
lease 0 2
ip cef
no ip bootp server
license udi pid CISCO861-K9 sn FGL162321F6
username XXXXX privilege 15 secret 4 /tX7S/B5iugv6vHRfWliaJnnb0lDLhN410OAwRQa3ZQ
ip tcp synwait-time 10
no ip address
no ip address
no ip address
no ip address
description $ES_WAN$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip tcp adjust-mss 1452
no autostate
ip http server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.1.100 name default-route
logging trap debugging
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
password 7 1239011A1B052E2D080E
login local
transport input telnet ssh
scheduler interval 500
end
In my Test environement all is OK now !
But still have issue when the physical link with two network is remplace by the radio link in real environement.
My router can reach all ressources on the main site. But l have to do the same action as l describe in my firts post before have a pc from my remote branch (site B) connected.
What do u think about the access-list command l finay delete ?
and what would be the best solution if we use 0.0.0.0 0.0.0.0 FastEthernet4 as default route ?
Can anyone confirm me that l can use the Fe4 (wan interface)  to connect my two network with a radio link ? ( not only use wan interface for internet access ) ?
Thanks and excuse for the delay
