Cisco 881?
magnocaiado
Hi, Good Day to all.
I need help from you in the configuration below.
When I connect the two wan links and interfaces Fe0 FE1, I browse, however software like skype keep falling and rising all the time.
I wonder where is the error in the configuration that is causing this?
System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
boot-start-marker
boot-end-marker
enable secret 5
aaa new-model
aaa authentication login SSH_aaa local
aaa authentication login CON_aaa local
aaa authorization console
aaa authorization exec SSH_aaa local
aaa authorization exec CON_aaa local
aaa session-id common
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FTX15288310
username xxxxx privilege 15
track 1 ip sla 1 reachability
delay down 9 up 10
track 2 ip sla 2 reachability
delay down 9 up 10
interface FastEthernet0
description Conexao BT
switchport access vlan 10
hold-queue 100 out
interface FastEthernet1
description Conexao Vodanet
switchport access vlan 20
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
description LAN
ip address 10.8.x.x 255.255.255.0
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Vlan10
description WAN 2
ip address 10.0.x.x 255.255.255.0
ip load-sharing per-packet
ip nat outside
hold-queue 100 out
interface Vlan20
description WAN 2
ip address 10.41.x.x 255.255.255.248
ip nat outside
hold-queue 100 out
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map RM-1 interface Vlan10 overload
ip nat inside source route-map RM-2 interface Vlan20 overload
ip route 0.0.0.0 0.0.0.0 10.0.x.x
ip route 0.0.0.0 0.0.0.0 10.41.x.x
ip access-list extended NATacl
permit ip 10.8.x.0 0.0.0.255 any
ip sla 1
icmp-echo 10.23.x.x source-interface Vlan10
frequency 3000
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 10.23.x.x source-interface Vlan20
frequency 3000
ip sla schedule 2 life forever start-time now
route-map RM-2 permit 10
match ip address NATacl
match interface Vlan20
route-map RM-1 permit 10
match interface Vlan10
control-plane
line con 0
logging synchronous
login authentication CON_aaa
no modem enable
line aux 0
line vty 0 4
exec-timeout 15 0
privilege level 15
password cisco
logging synchronous
login authentication SSH_aaa
transport input telnet ssh
scheduler max-task-time 5000
end
jurodri3
Hello Mr. Caiado,
Thank   you for posting, unfortunately the Cisco Support community is only   dedicate to Small business products and does not support CLI   configuration.
And the 881 is not considered as an Small business device.
In order to get an accurate and quick answer I recommend you to contact our Cisco support center.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html.
Diego Rodriguez
Cisco network engineer
Thank you.
Tagir Temirgaliyev
try to just disconnect one wan link. skype and internet should work
if not so i propose
to do
conf t
interface Vlan10
description WAN 2
no ip load-sharing per-packet
