cisco 881w and DHCP issue
sudden_buben
Hello.
I have a cisco 881W. My ISP give me two subnet and gateway for them (Fa4 IP address in my configuration). There are three subnet in my company
- two subnets within real IP addresses (a.a.a.x and b.b.b.x in my configuration below)
- one subnet eithin private IP addresses (c.c.c.x in my configuration below)
And DHCP for each. I made configuration on my cisco 881:
WAN port was gateway
LAN ports was separate on thee VLANs
So port Fa0 was insert to  VLAN1 (IP a.a.a.a), port Fa1 was insert to VLAN2 (IP b.b.b.b), port Fa2 was insert to VLAN3 (IP c.c.c.c)
Also I was creare three DHCP pools: pools for subnet a.a.a.a, b.b.b.b and c.c.c.c
But I have issue. When I connected any client into any ports from Fa0 to Fa2 it get rendom IP address from any three pools what I have. Another words if I connected client DHCP into port Fa0 I can will get not only address from pool for c.c.c.0 subnet but and for a.a.a.a subnet and for b.b.b.b subnet.
What me to do?
#sh run
Building configuration...
Current configuration : 3470 bytes
version 15.1
no service pad
service password-encryption
boot-start-marker
boot-end-marker
enable secret ----
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address c.c.c.1 c.c.c.100
ip dhcp pool pool
network c.c.c.0 255.255.255.0
default-router c.c.c.12
ip dhcp pool telephone
network a.a.a.208 255.255.255.248
default-router a.a.a.209
ip dhcp pool telephone1
network b.b.b.112 255.255.255.248
default-router b.b.b.113
interface FastEthernet0
switchport access vlan 1
no ip address
interface FastEthernet1
switchport access vlan 2
no ip address
interface FastEthernet2
switchport access vlan 3
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address <IP address> 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map oldshcool
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 192.168.255.100 255.255.255.0
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
ip address c.c.c.12 255.255.255.0
ip nat inside
interface Vlan2
ip address a.a.a.208 255.255.255.248
interface Vlan3
ip address b.b.b.112 255.255.255.248
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 <IP address>
logging esm config
access-list 100 permit ip c.c.c.0 0.0.0.255 any
end
sudden_buben
Found error in my post (original cisco configuration correct, I'm mistake only here)
interface Vlan2
ip address a.a.a.209 255.255.255.248
interface Vlan3
ip address b.b.b.113 255.255.255.248
could you post following outputs:
-sh vlan-sw br
-sh interface status
-sh ip dhcp bindings
- sh ip int br | i Vlan
Regards.
Alain
#sh vlan-sw br
VLAN Name                             Status    Ports
1    default                          active    Fa0, Fa3
3    VLAN0002                         active    Fa1
4    VLAN0003                         active    Fa2
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
#sh int status
Port    Name               Status       Vlan       Duplex Speed Type
Fa0                        connected    1          a-full   a-100 10/100BaseTX
Fa1                        connected    2          a-full   a-100 10/100BaseTX
Fa2                        connected    3          a-full   a-100 10/100BaseTX
Fa3                        notconnect   1            auto    auto 10/100BaseTX
Wl0     Internal switch in connected    trunk      a-full  a-1000 10/100BaseTX
#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
c.c.c.101      0164.00f1.7776.c0       Dec 21 2011 07:15 PM    Automatic
c.c.c.102      0100.1676.0e18.5c       Dec 21 2011 07:15 AM    Automatic
c.c.c.104      0100.1676.d3c0.4c       Dec 21 2011 07:17 AM    Automatic
c.c.c.187      011c.6f65.49f6.8d       Dec 21 2011 07:49 AM    Automatic
b.b.b.117      0100.0e08.3a29.a3       Dec 21 2011 07:16 AM    Automatic
#sh ip int br | i vlan
