Cisco 887 & 2960-S DHCP snooping problem
DOUGLAS DRURY
I've configured a Cisco 887va router with a set of Cisco 2960-S switches.  The problem is anyone on VLAN 30 is not getting an IP address.  VLANs 10 & 25 are getting IP addresses fine from my laptop acting as a DHCP server.  But VLAN 30 are not getting IP addresses from the 887 nor my laptop?
Any suggestions?
Cisco 887
MH-RT-HT-02#sh run br
Building configuration...
Current configuration : 4207 bytes
! Last configuration change at 06:28:32 UTC Fri Apr 8 2016
version 15.3
hostname MH-RT-HT-02
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret <Removed>
aaa new-model
aaa authentication login VPNUSERSAUTH local
aaa authorization network VPNUSERS local
aaa session-id common
crypto pki trustpoint TP-self-signed-2009019470
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2009019470
revocation-check none
rsakeypair TP-self-signed-2009019470
crypto pki certificate chain TP-self-signed-2009019470
certificate self-signed 01
ip dhcp excluded-address 192.168.30.1 192.168.30.10
ip dhcp excluded-address 192.168.30.200 192.168.30.254
ip dhcp pool MH-POOL
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
dns-server 192.168.30.1 8.8.8.8
domain-name <Removed>
lease 0 3
ip dhcp snooping vlan 10,25,30
ip dhcp snooping information option allow-untrusted
ip dhcp snooping
ip domain name <Removed>
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ195370MJ
<Removed>
controller VDSL 0
crypto isakmp policy 7
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group VPNUSERS
key <Removed>
dns 192.168.30.21
domain meldrum-ext.local
pool VPN-POOL
acl VPNSPLIT
crypto ipsec transform-set <Removed> esp-3des esp-md5-hmac
mode tunnel
crypto dynamic-map VPNDYNMAP 1
set transform-set <Removed>
reverse-route
crypto map MAP-OUTSIDE client authentication list VPNUSERSAUTH
crypto map MAP-OUTSIDE isakmp authorization list VPNUSERS
crypto map MAP-OUTSIDE client configuration address respond
crypto map MAP-OUTSIDE 1 ipsec-isakmp dynamic VPNDYNMAP
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
switchport access vlan 30
no ip address
ip dhcp snooping trust
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan30
description Guest_Extension
ip address 192.168.30.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname <Removed>
ppp chap password 0 <Removed>
ip local pool VPN-POOL 10.1.74.5 10.1.74.250
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list NAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended NAT
deny ip 192.168.30.0 0.0.0.255 10.1.74.0 0.0.0.255
permit ip 192.168.30.0 0.0.0.255 any
ip access-list extended VPNSPLIT
permit ip 192.168.30.0 0.0.0.255 10.1.74.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner login ^C
<Removed>
^C
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
transport input telnet ssh
transport output telnet ssh
scheduler allocate 20000 1000
end
MH-RT-HT-02#
Cisco 2960-S
I've set int gig 0/11 in vlan 30 as a test
MH-SW-HT-01#sh run br
Current configuration : 4526 bytes
version 12.2
no service pad
hostname MH-SW-HT-01
boot-start-marker
boot-end-marker
<Removed>
no aaa new-model
ip dhcp snooping
ip domain-name <Removed>
crypto pki trustpoint TP-self-signed-1326804608
subject-name cn=IOS-Self-Signed-Certificate-1326804608
rsakeypair TP-self-signed-1326804608
crypto pki certificate chain TP-self-signed-1326804608
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport trunk native vlan 10
switchport mode trunk
no ip address
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/3
switchport access vlan 10
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
shutdown
interface GigabitEthernet0/14
shutdown
interface GigabitEthernet0/15
shutdown
interface GigabitEthernet0/16
shutdown
interface GigabitEthernet0/17
shutdown
interface GigabitEthernet0/18
shutdown
interface GigabitEthernet0/19
shutdown
interface GigabitEthernet0/20
shutdown
interface GigabitEthernet0/21
shutdown
interface GigabitEthernet0/22
description Trunk to MH-SW-SB-01
interface GigabitEthernet0/23
description EtherChannel GP1 to MH-SW-EX-01
channel-group 1 mode desirable
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 192.168.10.203 255.255.255.0
no ip route-cache
ip http server
banner login ^C
<Removed>
^C
line con 0
logging synchronous
line vty 0 4
exec-timeout 0 0
privilege level 15
login local
line vty 5 15
login
end
MH-SW-HT-01#
Douglas,
Sorry I should have said.
For your set up you put
no ip dhcp snooping information option allow-untrusted
On both the router & the switch
Hopefully DHCP will work then on the ports on the router that are in Vlan 30 &
the same on the switch
Alex
Regards, Alex. Please rate useful posts.
6 Replies 6
What are the ports that connect 887 to 2960?
Hi Douglas,
As I see it you have configured DHCP snooping to look at option 82.
with the "ip dhcp snooping information option allow-untrusted" command.
But the DHCP server config for Vlan 30 does not have Option 82 configured.
Can you try
Then retest
If you want information abvout configuring option 82try this link:-
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/12-4t/dhcp-12-4t-book/config-dhcp-server.html#GUID-B439F785-79EE-467E-BB2B-240BE8E05293
Alex
Hi Alex,
Thanks for the reply.
What device would i run that command on?
887 fa0 to 2960 gig0/2
The PC connects to port gig0/11
Douglas,
Alex
Hi Alex,
I ran that command no ip dhcp snooping information option allow-untrusted on the switch and router but same issue so ran no ip dhcp snooping  leaving ip dhcp snooping vlan 10,25,30 in place.  By using no ip dhcp snooping will that have a negative affect?
I set up a rouge DHCP server on the same vlan to give out a different subnet (192.168.40.x) and the test PC got the correct IP from the 192.168.30x subnet.
Thanks for your help
