CISCO 887VA + Internet gateway - Vlan Problem
I have a problem with a recent network architecture that I wanted to implement in my home.
The network architecture is as the following:
Internet gateway router (SAGEM): 192.168.1.1 (DHCP Disabled) (WIFI Enabled)
Cisco 887VA router: 192.168.1.254 (DHCP enabled)
The SAGEM is connected to FE0 cisco port
This cisco router contains 3 vlans:
VLAN 1 : 192.168.1.254
VLAN 2: 192.168.2.1
VLAN 3: 192.168.3.1
I added a static routing in the internet gateway (SAGEM) thinking that I will need to get response back if anyone request from the other network vlans:
192.168.2.0 255.255.255.0 192.168.1.254
192.168.3.0 255.255.255.0 192.168.1.254
In the cisco router I added a static route as well: ip route 0.0.0.0 0.0.0.0 192.168.1.1
I do have internet in the VLAN 1. VLAN 2 and 3 don't have access to internet but the LAN devices can ping each other.
This is my cisco config:
Current configuration : 2045 bytes
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp excluded-address 192.168.2.1 192.168.2.50
ip dhcp excluded-address 192.168.3.1 192.168.3.50
ip dhcp pool USERS
 import all
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 8.8.8.8 8.8.4.4
ip dhcp pool SAVANT
 import all
 network 192.168.2.0 255.255.255.0
 default-router 192.168.2.1
ip dhcp pool SONOS
 import all
 network 192.168.3.0 255.255.255.0
 default-router 192.168.3.1
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ191471DA
controller VDSL 0
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Ethernet0
 no ip address
 shutdown
interface FastEthernet0
 no ip address
interface FastEthernet1
 switchport access vlan 2
 no ip address
interface FastEthernet2
 switchport access vlan 3
 no ip address
interface FastEthernet3
 no ip address
interface Vlan1
 ip address 192.168.1.254 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface Vlan2
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
interface Vlan3
 ip address 192.168.3.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 password xxxxxxx
 login
 no modem enable
line aux 0
line vty 0 4
 password xxxxxxx
 login
 transport input all
scheduler allocate 20000 1000
end
I need to know how to enable internet in vlan 2 and 3. Have I missed something ?
Thanks in advance for help me out.
What about putting Sagem into bridge mode using the public ip address on your FE0 router and using the pppoe setting on the Cisco side if that what the connection is , that way you can control all the nat on the Cisco side which is definitely capable iof doing multiple vlans nat , just an option
are the users in the vlan 2 and 3 wireless or wired , if wireless is it the same if there wired ? Just wondering is it having issues natting if there coming in by wireless as that's processed on sagem or if wireless is turned off
do you have access to the SAGEM router? perhaps it only can NAT the 192.168.1.0 network
Hi Richard Bradfield,
Thanks for your reply.
Yes I have access to SAGEM router. Actually, it seems that NAT option is missing I can't find anything related to it.
how to know that it can only nat 192.168.1.0 ?
