Bookmark
Subscribe
2277
Cisco 887VA need help for WLAN set up
santiago.li
Please help me to configure this router my main objective  is ADSL connection, and wireless network setup.
Any help for my basic configuration will be much appreciated
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 21-Mar-12 00:27 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
arcon uptime is 1 day, 2 hours, 45 minutes
System restarted at 05:09:55 UTC Sun Mar 24 2013
System image file is "flash:c880data-universalk9-mz.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 887VA (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FCZ170791T1
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO887VA-K9         FCZ170791T1
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
8 Replies 8
santiago.li
arcon(config)#int wlan1
% Invalid input detected at '^' marker.
I got this problem interface Wlan not working.
Please help. Thanks!
Your router model does not have wireless interface.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/eol_c51-631228.html
But in the front of my router it has LINK 2.4Ghz WLAN. what is this for?
The link that you gave is not for 887VA Paolo.
Can you post the following output:
1.  sh inventory
2.  sh ip int brie
3.  sh run | i service-module wlan-ap 0 boot image
You need to provide information about the configuration you want.  The 880 is capable of supporting up to 8 VLANs.  The built-in wireless AP can only support 802.11b/g and the antennas cannot be detached.
Information I would be looking for are:
1.  Are you going to use multiple SSID or single SSID?
2.  How many VLANs?
Hi Santiago.
The front panel of 887VA reports 2.4Ghz WLAN led in the front, but it hasn't any wireless capability. (i own an 887 VA too). It has a POE led too, but you need an adapter to get poe working.
What you need , for wireless connection is an 887VA-W
Carlo
Please rate all helpful posts "The more you help the more you learn"
santiago.li
1 SSID only I need and 1 Vlan also
sh inventory
NAME: "887VA", DESCR: "887VA chassis, Hw Serial#: FCZ170791T1, Hw Revision: 1.0"
PID: CISCO887VA-K9     , VID: V02, SN: FCZ170791T1
arcon#sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  down                  down
Dialer0                    unassigned      YES unset  up                    up
Ethernet0                  192.168.1.254   YES manual up                    down
FastEthernet0              unassigned      YES unset  administratively down down
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
Vlan1                      192.168.1.254   YES manual up                    up
arcon#sh run | i service-module wlan-ap 0 boot image
No built-in wireless AP available.
