09-13-2016
08:02 PM
- last edited on
03-25-2019
04:39 PM
by
ciscomoderator
I am trying to configure the wireless part on the cisco 887w router.
I am unable to enter the service module. I tried searching for answers in this forum, every answer is related to configuring the service module part, not related to accessing the service module.
I am trying to configure the wireless network on the same LAN VLAN 200, so i gave the command ip unnumbered vlan 200 and started the service module.
// r1#service-module wlan-ap 0 session
Trying 10.10.1.20, 2002 ... Open
Connecting to AP console, enter Ctrl-^ followed by x,
then "disconnect" to return to router prompt //
After this the whole thing just hangs, I cant even disconnect using control shift 6 and x.
I also tried creating a separate vlan for the wireless interface and separate ip, but still cant access the service module.
Gives the same error.
Help needed.
09-14-2016 03:58 AM
Try reset the session first and check the status as well
service-module wlan-ap0 status
service-module wlan-ap0 reset
if that does not work you could default it , this will wipe it
service-module wlan-ap0 reset default-config
09-14-2016 05:20 PM
After i apply the above commands, i get the following as the status
Service Module is Cisco wlan-ap0
Service Module supports session via TTY line 2
Service Module is trying to recover from error
Service Module reset on error is disabled
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
09-14-2016 05:32 PM
now it says
Service Module is trying to recover from reset/shutdown
09-14-2016 05:45 PM
and now it says
Service Module is failed
09-15-2016 01:19 AM
Honestly it sounds as if its gone faulty and may need to be replaced , they do go
could try this below or reload whole router as well in outage window incase its just locked up , other than that I would raise it with Cisco maybe get an RMA if it wont come online
https://supportforums.cisco.com/discussion/11562926/service-module-failed
