Cisco 890c-w can not routing with PPPoe
shoulham
I have a cisco 890c-w with routing and wireless,contain 8 switch ports(fastethernet 0 - 7),one 100m route port( fastethernnet 8),one giga port gigagethernet 0
configuration pppoe,dialer1 can get WAN IP。
0-7 ports in vlan2,vlan2  config ip add 192.168.1.1
In router,ping 8.8.8.8 is ok,but ping 8.8.8.8 source 192.168.1.1 can not ok,so my pc can not go internet through 0-7 ports。
I think routing problem,but don't find reason
pls help me!thank very much!!!
hostname Router
boot-start-marker
boot system flash c890-universalk9-mz.151-4.M2.bin
warm-reboot
boot-end-marker
enable password password
no aaa new-model
memory-size iomem 15
service-module wlan-ap 0 bootimage autonomous
ip source-route
ip cef
ip name-server 61.234.145.102
ip multicast-routing
no ipv6 cef
vpdn enable
vpdn-group PPPoE
license udi pid CISCO892C-W-C-K9 sn FCW1548000D
archive
log config
hidekeys
username admin password 0 password
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
switchport access vlan 2
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
no ip address
interface Vlan2
ip nat inside
interface Vlan20
no ip address
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap hostname 10108032
ppp chap password 0 888888
ppp pap sent-username 10108032 password 0 888888
no cdp enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
dialer-list 1 protocol ip permit
control-plane
mgcp profile default
line con 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
password password
login
transport input all
scheduler max-task-time 5000
end
kcnajaf
Level 7
Level 7
HI Han,
Can you try modfying the access list used for NAT as below.
no access-list 1 permit any
access-list 1 permit 192.168.1.0 0.0.0.255
Also please provide the output of "show ip Nat translation" when you initiate ping from the workstation.
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
HI Han,
Najaf
3ks
I had found this problem,modified config,is ok now
but i have one question,Do not permit any contain 192.168.1.0?
Hi Han,
Good question...But i'm not sure if that permit any is compatable with the NAT commmand :-) I will have to lab it up to check the same:-)
Najaf
thx
i wish to get your result!
