Web authentication on switches for 802.1x incompatible clients
Jaroslav Straka
Hello all,
excuse my english, it's not my first language. I am trying to get to work Web-based authentication on Catalyst 2960 and 3560 for clients that don't support dot1x. I followed this guide. Here's the problem: Client (win7) joins the network, opens the web browser and tries to navigate to any http site. The switch forces him the "login" page in which he has to enter credentials. After the client enters credentials, the switch sends http 500 internal server error page and nothing happens. Doesn't matter if the credentials were correct or not. Also i checked radius logs for requests, the switch doesn't even ask radius.
Could anyone please help with this? Or suggest where should i look, what debug messages to watch etc. Thanks.
The configuration:
sh ip admission configuration
Authentication Proxy Banner not configured
Consent Banner is not configured
Authentication Proxy webpage
        Login page              : flash:login.htm
        Success page            : flash:success.htm
        Fail page               : flash:fail.htm
        Login Expire page       : flash:expired.htm
Authentication global cache time is 60 minutes
Authentication global absolute time is 0 minutes
Authentication global init state time is 2 minutes
Authentication Proxy Watch-list is disabled
Authentication Proxy Max HTTP process is 7
Authentication Proxy Rule Configuration
Auth-proxy name sdj
    http list not specified inactivity-time 60 minutes
Authentication Proxy Auditing is disabled
Max Login attempts per user is 5
sh ru
aaa new-model
aaa authentication login default group radius local
aaa authentication dot1x default group radius
aaa authorization auth-proxy default group radius
ip device tracking
ip auth-proxy proxy http login expired page file flash:expired.htm
ip auth-proxy proxy http login page file flash:login.htm
ip auth-proxy proxy http success page file flash:success.htm
ip auth-proxy proxy http failure page file flash:fail.htm
ip admission proxy http login expired page file flash:expired.htm
ip admission proxy http login page file flash:login.htm
ip admission proxy http success page file flash:success.htm
ip admission proxy http failure page file flash:fail.htm
ip admission name sdj proxy http
radius-server dead-criteria tries 5
radius-server host xxxx auth-port 1812 acct-port 1813 key xxxxx
radius-server vsa send authentication
hi,
thanks for the config! kindly add:
ip http authentication aaa
is your radius an ACS server?
6 Replies 6
johnlloyd_13
Level 9
Level 9
hi,
can your switch ping the radius server?
kindly run the below and post them here:
debug radius authentication
test aaa group radius server new-code
Hi, yes it can, although only in legacy mode:
CVT_SC_CVT_0#debug radius authentication
Radius protocol debugging is on
Radius protocol brief debugging is off
Radius protocol verbose debugging is off
Radius packet hex dump debugging is off
Radius packet protocol (authentication) debugging is on
Radius packet protocol (accounting) debugging is off
Radius elog debugging debugging is off
Radius packet retransmission debugging is off
Radius server fail-over debugging is off
CVT_SC_CVT_0#test aaa group radius server xxxx checkservice abc123 new-code
Unable to find specified server in group.
CVT_SC_CVT_0#test aaa group radius server xxxx checkservice abc123 legacy
Attempting authentication test to server-group radius using radius
User was successfully authenticated.
CVT_SC_CVT_0#test aaa group radius server xxxx checkservice wrongpassword legacy
User authentication request was rejected by server.
Ok so your switch can talk to radius. Have you applied the proxy rule on the switch ports?
Kindly post show run and remove sensitive data.
int fast x/x
ip admission NAME
authentication order webauth
There it is, I've removed some sensitive data, unused interfaces and vlan info. I am trying this on int gi0/37. int gi0/48 is "input" to the switch. Cheers for the help!
For some reason this forum couldn't allow me to post it here, it says "This message can not be displayed due to its content.  Please use the contact us link with any questions." So i had to post it here
http://pastebin.com/qDZeDsg9
hi,
No i don't think so, it's just freeradius daemon on a linux host.
But thanks!
ip http authentication aaa did it, i need some more testing but at first sight it works as i imagined
That command is nowhere in the Configuring Web-Based Authentication guide on cisco.com though.
