Cisco 891 VPN Connection issue with OpenSwan
szpuni123
I have a small issue with VPN between my linux server (ubuntu with openswan) and cisco891.
Tunel is up and running but I can access devices only from cisco side but if I try to ping any device on cisco side I cannot connect to anything.
crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
111.111.111.111   222.222.222.222    QM_IDLE           2001 ACTIVE
In this example 111.111.111.111 is a cisco and 222.222.222.222 is a linux server both with external ip's
Lan side is 192.168.2.1 for cisco and 192.168.90.10 for linux.
With that tunnel running i can ping 192.168.90.10 from any device in 192.168.2.0/24 network but if I try do reverse I mean from cisco to ping any device in 2.0 network I have no reply from any device.
Any ideas?
Config below:
no ip domain lookup
ip domain name actualgaming.com
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip cef
no ipv6 cef
object-group network GAMESERVERS
host 1.1.1.1
object-group network MONITORING
host 222.222.222.222
object-group network WEBSERVERS
host 3.3.3.3
object-group network PERSONAL
host 4.4.4.4
redundancy
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp policy 2
encr 3des
group 2
lifetime 28800
crypto isakmp key secretpassword address  222.222.222.222
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set cm-transformset-1 esp-aes esp-sha-hmac
crypto map cm-cryptomap local-address GigabitEthernet0
crypto map cm-cryptomap 1 ipsec-isakmp
set peer 222.222.222.222
set security-association lifetime kilobytes 46080000
set transform-set cm-transformset-1
match address 110
interface GigabitEthernet0
description $ES_WAN$$FW_OUTSIDE$
ip address 111.111.111.186 255.255.255.252
ip access-group MAIN_IN in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip inspect DEFAULT100 out
ip virtual-reassembly in
duplex full
speed 100
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.2.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip tcp adjust-mss 1452
ip nat inside source route-map ISP interface GigabitEthernet0 overload
ip nat inside source static tcp 192.168.2.103 22 111.111.111.186 65022 route-map ISP extendable
ip nat inside source static tcp 192.168.2.103 5555 111.111.111.186 65101 route-map ISP extendable
ip nat inside source static tcp 192.168.2.104 5555 111.111.111.186 65102 route-map ISP extendable
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 111.111.111.185 10
ip access-list extended NAT
deny   ip any 10.0.0.0 0.255.255.255
deny   ip any 192.168.0.0 0.0.255.255
deny   ip any 172.16.0.0 0.15.255.255
permit ip 192.168.2.0 0.0.0.255 any
ip access-list extended MAIN_IN
permit ip object-group GAMESERVERS any
permit ip object-group WEBSERVERS any
permit ip object-group PERSONAL any
permit ip object-group MONITORING any
permit icmp any any
deny   ip any any log
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
route-map ISP permit 10
match ip address NAT
match interface GigabitEthernet0
XIE YAO
normally it's caused by interesting cal mismatch, have you checked that on both sides?
I'm sorry but not quite understand what are you asking here.
What sort of call mismatch you are talking about here?
I had very similar setup working with centos with same open swan configuration which I can post here if required but for some reason in this setup i can only achive one way comunication strangely...
Nodoby can help me with that?
