07-21-2015 04:20 PM - edited 03-08-2019 01:03 AM
Just in the middle of configuring an 891W remotely, when I lost contact, and the local person said all Leds flashing off and on continually every 4 seconds, no console output, recycled power, took to different power outlet still the same can't do anything with it!
I have never seen this type of problem before anybody any ideas about this?
07-22-2015 05:30 AM
If theres no console access its in a bad way , only thing left to try before RMA is a factory reset , did you have terminal monitor running when configuring it remotely did anything show up before it dropped , are you 100% console is not working i would try a couple of different pcs and cables just in case
factory reset guide
07-22-2015 04:19 PM
all cables etc. are ok, put in an 881 as a temporary replacement that is working ok.
I want to try using the reset button, But can't find any information on when to use it., do I just power on with the reset button pressed?
07-23-2015 12:11 AM
As the router is booting up has to be within the first 5 seconds hold in the reset button with a pin while consoled in and you will see the router go back to factory reset, it loads up the original default file inside the router
07-29-2018 11:09 AM
I have the same problem, have you been able to fix it ?
07-29-2018 11:12 AM
Small addition i have the console port giving me "□ □ □ □ □ □ □" the squares are increasing. I tried multiple setup of the console port without any success.
