02-12-2022 01:35 PM
the sh flash give me the 846200832 bytes available (1011351552 bytes used)
the total files length is 495013974 not 1011351552.
I removed an old bin file (about 500Mb) but it looks like it hasn't been removed
the file does not appear in sh flash command.
Suggestions ?
02-12-2022 01:43 PM
you can delete old files:
#install remove inactive
To suggest better post
dir flash: (post full output)
02-12-2022 03:44 PM
Please post the complete output to the following commands:
sh version dir flash: dir flash:/core dir crashinfo:
02-13-2022 12:52 AM
hello, thanks for reply
here the data
Switch_SEDE#dir flash-6:
Directory of flash-6:/
48577 drwx 4096 Feb 11 2022 17:52:38 +01:00 .installer
72867 drwx 4096 Feb 11 2022 17:46:41 +01:00 license_evlog
16197 -rw- 2097152 Feb 11 2022 10:33:28 +01:00 nvram_config
64769 drwx 4096 Feb 9 2022 09:59:08 +01:00 .prst_sync
16200 -rw- 15500 Feb 9 2022 09:56:55 +01:00 rdope_out.txt
16205 -rw- 0 Feb 9 2022 09:56:55 +01:00 dope_hist
16201 -rw- 89 Feb 9 2022 09:56:52 +01:00 rdope.log
16198 -rw- 134458 Feb 9 2022 09:54:44 +01:00 memleak.tcl
16194 -rw- 2148 Feb 9 2022 09:54:29 +01:00 boothelper.log
105272 drwx 4096 Feb 9 2022 09:54:27 +01:00 dc_profile_dir
16195 -rw- 1369 Feb 9 2022 09:54:08 +01:00 bootloader_evt_handle.log
16203 -rw- 736 Feb 9 2022 08:09:06 +01:00 vlan.dat
16202 -rw- 2148 Feb 7 2022 13:46:31 +01:00 boothelper.log.old
16204 -rw- 2097152 Feb 1 2022 19:09:34 +01:00 nvram_config_bkup
48582 drwx 4096 Jan 31 2022 16:08:08 +01:00 .dbpersist
16206 drwx 4096 Jan 14 2022 12:16:01 +01:00 .rommon_sync
56673 drwx 4096 Oct 17 2021 22:16:15 +02:00 .rollback_timer
72881 -rw- 4919 Oct 17 2021 22:11:12 +02:00 packages.conf
72885 -rw- 40714229 Oct 17 2021 22:11:11 +02:00 cat9k_lite-rpboot.17.03.04.SPA.pkg
72884 -rw- 11035668 Oct 17 2021 22:09:44 +02:00 cat9k_lite-webui.17.03.04.SPA.pkg
72883 -rw- 4256792 Oct 17 2021 22:09:43 +02:00 cat9k_lite-srdriver.17.03.04.SPA.pkg
72882 -rw- 427201560 Oct 17 2021 22:09:43 +02:00 cat9k_lite-rpbase.17.03.04.SPA.pkg
48587 drwx 4096 Oct 17 2021 22:03:55 +02:00 pnp-tech
48580 drwx 4096 Oct 17 2021 22:03:33 +02:00 core
32388 drwx 4096 Oct 17 2021 22:03:30 +02:00 guest-share
32386 drwx 4096 Oct 17 2021 22:03:12 +02:00 onep
32385 drwx 4096 Oct 17 2021 22:03:12 +02:00 pnp-info
113345 drwx 4096 Oct 17 2021 22:02:15 +02:00 .USWAP
24289 drwx 4096 Oct 17 2021 22:02:06 +02:00 Tbot
8097 drwx 4096 Oct 17 2021 22:02:05 +02:00 .CRFT
105274 drwx 4096 Oct 17 2021 22:02:00 +02:00 sys_report
105249 drwx 4096 Oct 17 2021 22:01:58 +02:00 tech_support
89057 drwx 4096 Oct 17 2021 22:01:58 +02:00 ss_disc
16196 -rw- 5242880 Oct 17 2021 22:01:58 +02:00 ssd
64772 drwx 4096 Oct 17 2021 20:38:39 +02:00 gs_script
1957167104 bytes total (846200832 bytes free)
Switch_SEDE#dir flash-6:/core
Directory of flash-6:/core/
48583 -rw- 1 Jan 14 2022 11:46:40 +01:00 .callhome
80961 drwx 4096 Oct 17 2021 22:01:55 +02:00 modules
Switch_SEDE#dir crashinfo-6:
Directory of crashinfo-6:/
14657 drwx 61440 Feb 13 2022 09:43:31 +01:00 tracelogs
825753600 bytes total (770179072 bytes free)
Switch_SEDE#sh flash-6:
-#- --length-- ---------date/time--------- path
2 2148 Feb 09 2022 09:54:29.0000000000 +00:00 boothelper.log
3 0 Feb 09 2022 09:56:55.0000000000 +00:00 dope_hist
4 4096 Feb 11 2022 17:52:38.0000000000 +00:00 .installer
5 5 Jan 31 2022 17:29:22.0000000000 +00:00 .installer/install_global_trans_lock
6 14 Feb 09 2022 09:55:37.0000000000 +00:00 .installer/watchlist
7 4096 Feb 07 2022 11:03:58.0000000000 +00:00 .installer/rollback
8 56 Feb 07 2022 11:03:58.0000000000 +00:00 .installer/rollback/rollback_points.txt
9 4096 Feb 07 2022 11:03:58.0000000000 +00:00 .installer/rollback/rb_points
10 4096 Oct 17 2021 22:16:39.0000000000 +00:00 .installer/rollback/rb_points/1
11 4919 Oct 17 2021 22:16:15.0000000000 +00:00 .installer/rollback/rb_points/1/packages.conf
12 6 Oct 17 2021 22:16:15.0000000000 +00:00 .installer/rollback/rb_points/1/bootdir
13 624 Oct 17 2021 22:16:39.0000000000 +00:00 .installer/rollback/rb_points/1/pkginfo
14 0 Oct 17 2021 22:16:39.0000000000 +00:00 .installer/rollback/rb_points/1/patch0.sta
15 10 Oct 17 2021 22:16:39.0000000000 +00:00 .installer/rollback/rb_points/1/patch.sta
16 0 Feb 11 2022 17:37:54.0000000000 +00:00 .installer/.install_add_pkg_list.prev.txt
17 365 Feb 11 2022 17:38:02.0000000000 +00:00 .installer/install_add_oper.log
18 10 Feb 09 2022 09:55:53.0000000000 +00:00 .installer/install_state
19 4096 Oct 17 2021 22:16:15.0000000000 +00:00 .rollback_timer
20 1369 Feb 09 2022 09:54:08.0000000000 +00:00 bootloader_evt_handle.log
21 4096 Oct 17 2021 22:03:33.0000000000 +00:00 core
22 4096 Oct 17 2021 22:01:55.0000000000 +00:00 core/modules
23 1 Jan 14 2022 11:46:40.0000000000 +00:00 core/.callhome
24 4096 Feb 09 2022 09:59:08.0000000000 +00:00 .prst_sync
25 310 Feb 09 2022 09:54:26.0000000000 +00:00 .prst_sync/log
26 42 Feb 09 2022 09:54:26.0000000000 +00:00 .prst_sync/reload_history
27 4096 Oct 17 2021 20:38:39.0000000000 +00:00 gs_script
28 4096 Oct 17 2021 20:38:39.0000000000 +00:00 gs_script/sss
29 5242880 Oct 17 2021 22:01:58.0000000000 +00:00 ssd
30 4096 Oct 17 2021 22:01:58.0000000000 +00:00 ss_disc
31 4096 Oct 17 2021 22:01:58.0000000000 +00:00 tech_support
32 15305 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/igmp-snooping.tcl
33 13515 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/mld-snooping.tcl
34 15828 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/multicast.tcl
35 1330 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/pkt-drop-stats-dump.tcl
36 14047 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/pkt-drop-stats.tcl
37 1365 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/platform-fabric-iid-ethernet.tcl
38 2107 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/platform-fabric-iid-ipv4.tcl
39 2109 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/platform-fabric-iid-ipv6.tcl
40 2729 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/platform-fabric-vrf-ipv4.tcl
41 2757 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/platform-fabric-vrf-ipv6.tcl
42 52363 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/platform-fabric-vrf-source.tcl
43 612 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/platform-fabric.tcl
44 1548 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/platform_evpn_vxlan.tcl
45 26175 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/port.tcl
46 3215 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/port_dump.tcl
47 8171 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/port_utils.tcl
48 15655 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/stack.tcl
49 4937 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/stackwise-virtual.tcl
50 1496 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/tech-support-confidential.tcl
51 685 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/tech-support-dump.tcl
52 38541 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/unicast.tcl
53 336 Feb 09 2022 09:54:27.0000000000 +00:00 tech_support/utils.tcl
54 4096 Feb 09 2022 09:54:27.0000000000 +00:00 dc_profile_dir
55 251645 Feb 09 2022 09:54:27.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt
56 251645 Feb 07 2022 13:46:29.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt.bkp
57 2097152 Feb 11 2022 10:33:28.0000000000 +00:00 nvram_config
58 4096 Oct 17 2021 22:02:00.0000000000 +00:00 sys_report
59 4096 Oct 17 2021 22:02:15.0000000000 +00:00 .USWAP
60 4096 Oct 17 2021 22:02:05.0000000000 +00:00 .USWAP/rp
61 4096 Oct 17 2021 22:02:10.0000000000 +00:00 .USWAP/fp
62 4096 Oct 17 2021 22:02:15.0000000000 +00:00 .USWAP/cc
63 4096 Oct 17 2021 22:02:05.0000000000 +00:00 .CRFT
64 134458 Feb 09 2022 09:54:44.0000000000 +00:00 memleak.tcl
65 4096 Oct 17 2021 22:02:06.0000000000 +00:00 Tbot
66 117906 Feb 09 2022 09:54:44.0000000000 +00:00 Tbot/HealthCheckDebugInfra.py
67 265373 Feb 09 2022 09:54:44.0000000000 +00:00 Tbot/L3ParseOutputs.py
68 365279 Feb 09 2022 09:54:44.0000000000 +00:00 Tbot/L3DebugInfraAPIs.py
69 155706 Feb 09 2022 09:54:44.0000000000 +00:00 Tbot/L2DebugInfraAPIs.py
70 164575 Feb 09 2022 09:54:44.0000000000 +00:00 Tbot/L2ParseOutputs.py
71 155706 Feb 09 2022 09:54:44.0000000000 +00:00 Tbot/L2DebugInfraScript.py
72 13 Oct 17 2021 22:02:07.0000000000 +00:00 NVRAM
73 4096 Jan 31 2022 16:08:08.0000000000 +00:00 .dbpersist
74 4096 Jan 31 2022 16:08:08.0000000000 +00:00 .dbpersist/history
75 4096 Jan 31 2022 16:08:08.0000000000 +00:00 .dbpersist/DMI_STATE_DB
76 745 Jan 31 2022 16:08:08.0000000000 +00:00 .dbpersist/stats
77 15500 Feb 09 2022 09:56:55.0000000000 +00:00 rdope_out.txt
78 4096 Oct 17 2021 22:03:12.0000000000 +00:00 pnp-info
79 4096 Oct 17 2021 22:03:12.0000000000 +00:00 onep
80 4096 Oct 17 2021 22:03:12.0000000000 +00:00 onep/apps-cli
81 89 Feb 09 2022 09:56:52.0000000000 +00:00 rdope.log
82 4096 Feb 11 2022 17:46:41.0000000000 +00:00 license_evlog
83 4096 Jan 14 2022 12:16:01.0000000000 +00:00 .rommon_sync
84 670 Feb 09 2022 09:52:42.0000000000 +00:00 .rommon_sync/env_var
85 4096 Oct 17 2021 22:03:30.0000000000 +00:00 guest-share
86 736 Feb 09 2022 08:09:06.0000000000 +00:00 vlan.dat
87 2097152 Feb 01 2022 19:09:34.0000000000 +00:00 nvram_config_bkup
88 4096 Oct 17 2021 22:03:55.0000000000 +00:00 pnp-tech
89 5577 Oct 17 2021 22:03:55.0000000000 +00:00 pnp-tech/pnp-tech-time
90 118266 Oct 17 2021 22:03:56.0000000000 +00:00 pnp-tech/pnp-tech-discovery-summary
91 4919 Oct 17 2021 22:11:12.0000000000 +00:00 packages.conf
92 427201560 Oct 17 2021 22:09:43.0000000000 +00:00 cat9k_lite-rpbase.17.03.04.SPA.pkg
93 40714229 Oct 17 2021 22:11:11.0000000000 +00:00 cat9k_lite-rpboot.17.03.04.SPA.pkg
94 4256792 Oct 17 2021 22:09:43.0000000000 +00:00 cat9k_lite-srdriver.17.03.04.SPA.pkg
95 11035668 Oct 17 2021 22:09:44.0000000000 +00:00 cat9k_lite-webui.17.03.04.SPA.pkg
96 2148 Feb 07 2022 13:46:31.0000000000 +00:00 boothelper.log.old
the total length is not 1011351552 but 495013974
it appears that the old file is still in the flash
it appears that the old bin file is still in the flash
02-13-2022 01:49 AM
We could be looking at a bug where the flash space does not marry up.
17.3.5 was released yesterday. Upgrade to that and see if there are any improvements.
02-13-2022 02:00 AM
upgrading is the problem
the switch is in a stack and the process abort with the error
in the unit 6. Not enough space in the flash !!
02-13-2022 02:41 AM
- On the particular unit try : fsck flash: , check if that can help.
M.
02-13-2022 03:12 AM - edited 02-13-2022 03:13 AM
Post the complete output to the command "sh version".
I think I know what this is.
And if this is what I think it is, there are two "dirty" ways of fixing this.
02-13-2022 07:23 AM
here the show version
Cisco IOS XE Software, Version 17.03.04
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Fri 02-Jul-21 19:32 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.5.1r [FC4], RELEASE SOFTWARE (P)
Switch_SEDE uptime is 4 days, 6 hours, 25 minutes
Uptime for this control processor is 4 days, 6 hours, 28 minutes
System returned to ROM by Power Failure or Unknown
System restarted at 09:56:28 CET Wed Feb 9 2022
System image file is "flash:packages.conf"
Last reload reason: Power Failure or Unknown
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco C9200-48P (ARM64) processor with 652851K/3071K bytes of memory.
Processor board ID JAE254210AM
4 Virtual Ethernet interfaces
416 Gigabit Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4028872K bytes of physical memory.
819200K bytes of Crash Files at crashinfo:.
819200K bytes of Crash Files at crashinfo-2:.
819200K bytes of Crash Files at crashinfo-3:.
819200K bytes of Crash Files at crashinfo-4:.
819200K bytes of Crash Files at crashinfo-5:.
819200K bytes of Crash Files at crashinfo-6:.
819200K bytes of Crash Files at crashinfo-7:.
819200K bytes of Crash Files at crashinfo-8:.
1941504K bytes of Flash at flash:.
1941504K bytes of Flash at flash-2:.
1941504K bytes of Flash at flash-3:.
1941504K bytes of Flash at flash-4:.
1941504K bytes of Flash at flash-5:.
1941504K bytes of Flash at flash-6:.
1941504K bytes of Flash at flash-7:.
1941504K bytes of Flash at flash-8:.
15359936K bytes of USB Flash at usbflash0:.
Base Ethernet MAC Address : 80:24:8f:38:01:80
Motherboard Assembly Number : 73-20259-03
Motherboard Serial Number : JAE254210AM
Model Revision Number : C0
Motherboard Revision Number : A0
Model Number : C9200-48P
System Serial Number : JAE254210AM
CLEI Code Number : INM9200ERB
Switch Ports Model SW Version SW Image Mode
* 1 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
2 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
3 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
4 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
5 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
6 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
7 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
8 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
Switch 02
Switch uptime : 4 days, 6 hours, 29 minutes
Base Ethernet MAC Address : 80:24:8f:45:6c:00
Motherboard Serial Number : JAE2542118H
System Serial Number : JAE2542118H
Last reload reason : Power Failure or Unknown
Switch 03
Switch uptime : 4 days, 6 hours, 28 minutes
Base Ethernet MAC Address : 80:24:8f:6a:3f:00
Motherboard Serial Number : JAE254210F7
System Serial Number : JAE254210F7
Switch 04
Base Ethernet MAC Address : 80:24:8f:45:6e:80
Motherboard Serial Number : JAE254210Q1
System Serial Number : JAE254210Q1
Switch 05
Base Ethernet MAC Address : c4:4d:84:f7:0b:00
Motherboard Serial Number : JAE254211UM
System Serial Number : JAE254211UM
Last reload reason : lost both active and standby
Switch 06
Base Ethernet MAC Address : d4:eb:68:e9:1f:80
Motherboard Serial Number : JAE254210LZ
System Serial Number : JAE254210LZ
Switch 07
Base Ethernet MAC Address : 80:24:8f:45:62:80
Motherboard Serial Number : JAE25420YRJ
System Serial Number : JAE25420YRJ
Switch 08
Base Ethernet MAC Address : d4:eb:68:e9:1e:80
Motherboard Serial Number : JAE25420ZEQ
System Serial Number : JAE25420ZEQ
Configuration register is 0x102
02-13-2022 02:00 PM
Oh look here! `tis my friend, "EHSA standby down".
This crash is most likely caused by a generic crashinfo/error/core message called "EHSA standby down". It is generic because if the crash is unknown, the switch uses "EHSA standby down" as an excuse.
Catalyst 3850 and Catalyst 9300 suffers this bug since 16.12.4 (and later), but 9200 has this bug in 17.X.X.
02-13-2022 04:30 AM
other than upgrade, quick question..why flash-6? here is this part of stack?
02-13-2022 07:24 AM
yes there are 8 switches in the stack
02-13-2022 06:03 AM
Hello furio,
Please, compare the amount space in the flash of the Active|Standby and other Members of the stack. If they seem to have about the same contents and same space available, but only switch 6 is facing this issue, you can try to format the flash and|or fsck flash.(switch 6) If this does not help the device could be facing a hardware issue and should be replaced.
Leonardo
02-13-2022 10:10 AM
Switch_SEDE#sh file system
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw system:
- - opaque rw tmpsys:
825638912 459108352 disk rw crashinfo: crashinfo-1:
825753600 448790528 disk rw crashinfo-2: stby-crashinfo:
825753600 685244416 disk rw crashinfo-3:
825753600 663224320 disk rw crashinfo-4:
825753600 654311424 disk rw crashinfo-5:
825753600 770179072 disk rw crashinfo-6:
825753600 552075264 disk rw crashinfo-7:
825753600 691535872 disk rw crashinfo-8:
* 1956839424 1358409728 disk rw flash: bootflash: flash-1:
1957167104 1358954496 disk rw flash-2: stby-flash:
1957167104 1358954496 disk rw flash-3:
1957167104 1358430208 disk rw flash-4:
1957167104 1358954496 disk rw flash-5:
1957167104 846200832 disk rw flash-6:
1957167104 1358430208 disk rw flash-7:
1957167104 1358954496 disk rw flash-8:
1980604416 1913253888 disk ro webui:
- - opaque rw null:
- - opaque ro tar:
- - network rw tftp:
2097152 2057608 nvram rw nvram:
- - opaque wo syslog:
- - network rw rcp:
- - network rw http:
- - network rw ftp:
- - network rw scp:
- - network rw sftp:
- - network rw https:
- - opaque ro cns:
2097152 2057608 nvram rw stby-nvram:
- - nvram rw stby-rcsf:
- - opaque rw revrcsf:
15711797248 15159959552 disk rw usbflash0:
02-13-2022 02:06 PM
Alright, not talking about "EHSA standby down", the way to solve this problem about "not enough flash space in switch 6", I have three options. Options two and three is very "dirty" (aka NSFW).
Option 1: Cold reboot (pull the power cable from the switch)
If Option 1, did not improve things, move to the next.
Option 2: Remove all the stacking cables from switch 6 and force the switch 6 to boot into Bundle Mode;
If switch 6 still refuses to boot into Bundle Mode look at Option 3
Option 3: Still without any stacking cables attached, force the switch to boot into ROMMON and initiate Emergency Install.
(Remember, switch 6 is part of a stack. It does not matter if the switch is completely wiped of any config. Once switch 6 joins the stack it will download the complete config from the master.)
