Cisco 9200L cant write mem
Pulsant
Have 3 x  C9200L-48P-4X in a stack and all of a sudden after a month i cant do a write mem, it saves the config through the GUI, but not the IOS. I receive the following error
Admin9200L_Stack#wr mem
startup-config file open failed (Device or resource busy)
Switch Ports Model SW Version SW Image Mode
* 1 52 C9200L-48P-4X 16.9.4 CAT9K_LITE_IOSXE INSTALL
2 52 C9200L-48P-4X 16.9.4 CAT9K_LITE_IOSXE INSTALL
3 52 C9200L-48P-4X 16.9.4 CAT9K_LITE_IOSXE INSTALL
6 Replies 6
Martin L
weird, maybe someone has hacked your stack ;)
I assume copy run start also does not work, right?
what about your access level or trying via console.
I have full priv 15 , just noticed i cant dir nvram just hangs no error
Admin9200L_Stack#dir nvram:
Directory of nvram:/
%Error opening nvram:/ (Permission denied)
Admin9200L_Stack#sh startup-config
Error accessing startup-config (Device or resource busy)
maybe flash went bad. dir to see all storage places included flash: (if it is not broken)
mikaelkarlgren
Have the same issue. Did you resolve this?
Deepak Kumar
clear line vty X
Clear all vty/console lines and make sure only you are connected to the switch. Any of the sessions are running a process that is writing to flash that might have been hung.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
Show users
Clear line xxx
test again
Kind Regards
Paul
