Cisco 9300 Password Recovery not working
Omar1212
Hi All,
I am currently stuck in a situation where I am locked out of a stack of 9300 switches.
I have copied the username and the hashed password from a backup config that we had as this is a new switch model than the current one we have.
Switching, Catalyst 9000, Other Switches, LAN SwitchingSwitching, Catalyst 9000, Other Switches, LAN SwitchingSwitching, Catalyst 9000, Other Switches, LAN Switching
The problem I have a the moment and I am not sure how it happened is that I have been locked out of the switch as the password is not working.
I have tried rommon access through pressing the mode button a couple of time after the system light reboots and that gets me into the bootloader.
With "switch:" prompt  have tried as suggested "SWITCH_IGNORE_STARTUP_CFG=1" and copied and pasted that command then ran "boot" to reboot the stack, however the stack still boots with the start up config like I never even put the command in.
I am a bit lost on what to do at this point and I cant seem to find anyone who has had the same issue
Any help is appreciated . Thanks
Remove the stacking cable.
Perform the password-recovery.
14 Replies 14
balaji.bandi
Thanks for the reply. As mentioned in the post I have tried this and the command ""SWITCH_IGNORE_STARTUP_CFG=1" does not seem to take any effect.
May be there is small command missing while doing, can you capture the console output full and post us for reference, what is going wrong to identify (right from boot)
BB
Thanks I am accessing the switch via RDP and console so I have no one on site at the moment to further reboot and get back into ROMMON .  However I was able to extract this from the putty terminal session as I left it open. Please find below:
Press RETURN to get started.
Initializing Hardware...
Correcting the primary Nvram
System Bootstrap, Version 16.12.2r, RELEASE SOFTWARE (P)
Compiled Fri 10/25/2019 11:48:55.48 by rel
Current ROMMON image : Primary
Last reset cause : PowerOn
C9300L-24T-4X platform with 8388608 Kbytes of main memory
boot: attempting to boot from [flash:packages.conf] (interrupted)
switch: SWITCH_IGNORE_STARTUP_CFG=1
switch: dir flash:
Size Attributes Name
2097152 -rw- nvram_config
2097152 -rw- nvram_config_bkup
14464008 -rw- cat9k-cc_srdriver.16.12.04.SPA.pkg
89134084 -rw- cat9k-espbase.16.12.04.SPA.pkg
1684484 -rw- cat9k-guestshell.16.12.04.SPA.pkg
531063808 -rw- cat9k-rpbase.16.12.04.SPA.pkg
31478788 -rw- cat9k-sipbase.16.12.04.SPA.pkg
60392448 -rw- cat9k-sipspa.16.12.04.SPA.pkg
23217156 -rw- cat9k-srdriver.16.12.04.SPA.pkg
12907520 -rw- cat9k-webui.16.12.04.SPA.pkg
9216 -rw- cat9k-wlc.16.12.04.SPA.pkg
6648 -rw- packages.conf
41799673 -rw- cat9k-rpboot.16.12.04.SPA.pkg
4096 drw- .installer
444 -rw- bootloader_evt_handle.log
4096 drw- core
4096 drw- .prst_sync
4096 drw- .rollback_timer
4096 drw- gs_script
4096 drw- tech_support
4096 drw- dc_profile_dir
395 -rw- boothelper.log
132108 -rw- memleak.tcl
1953 -rw- svl_ipc.tcl
0 -rw- NVRAM
4096 drw- .dbpersist
4096 drw- onep
16089 -rw- rdope_out.txt
89 -rw- rdope.log
0 -rw- dope_hist
35 -rw- pnp-tech-time
108342 -rw- pnp-tech-discovery-summary
1036 -rw- vlan.dat
switch:
switch: boot
boot: reading file packages.conf
Waiting for 120 seconds for other switches to boot
Switch number is 2
All switches in the stack have been discovered. Accelerating discovery
Is this switch still connected with a stacking cable?
yes currently they are still in the stack. I did read online and it mentioned as long as I do the same procedure on the master it should go be the same. Do you think I need to do every single switch on its own ?
OMfG.  <FACEPALM>
That is why password recovery will not work because they are still in a stack!
If the master has the complete config, it does not matter if the slave switch has password-recovery configured.  As soon the switch detects the master through the stacking cable, the switch will download the config and rendering the password-recovery settings moot.
right !
So do you recommend removing them from the stack and doing each switch on their own.
Thanks you are right . consoling onto the other switch and I found out that its up with the config .
I disconnected the stacking cables and done the password recovery on the master and that has worked.
Thanks for your help
Happy to help.
Leo Laohoo
After entering this command, post the complete output to the ROMMON command of "set".
Thanks for the reply I will get the output as soon as possible.
I was getting access to the switch through RDP  to a PC on site while having someone reboot the switch for me. as soon as I get that I will update here.
Hi  Please find below the output of the "set" command :
I noticed the switch number is saying 2 however as far as I know you cant console on the on master switch.
Do you think its related to that ?
Thanks.
BAUD=9600
BOARDID=24677
BOOT=flash:packages.conf;
BOOTLDR=
BSI=0
CONFIG_FILE=
MAC_ADDR=F8:7A:41:46:8A:00
MANUAL_BOOT=no
MODEL_NUM=C9300L-24T-4X
MODEL_REVISION_NUM=F0
MOTHERBOARD_ASSEMBLY_NUM=73-19168-04
MOTHERBOARD_REVISION_NUM=C0
MOTHERBOARD_SERIAL_NUM=FOC2509008P
RANDOM_NUM=1400769744
RET_2_RCALTS=
ROMMON_AUTOBOOT_ATTEMPT=3
SWITCH_NUMBER=2
SWITCH_PRIORITY=13
SYSTEM_SERIAL_NUM=FOC2509L7HD
TEMPLATE=access
VERSION_ID=V01
