Cisco 9300 Switch DHCP Snooping turned on Will not pull DHCP IP's
PTerranova13
I have 3 new stacks of 9300 switches. 2 of the stacks work fine with DHCP Snooping on. 1 Stack does not. When the below commands are on the switch DHCP will not pulled. When i remove them IP's pull. I have reloaded the switch and still doesnt work.
IOS 16.12.4
The following commands are on the switch
ip dhcp snooping vlan 1-4094
no ip dhcp snooping information option
ip dhcp snooping
Two trunk fiber ports back to core
IND-IDF-08#sh run int t1/1/1
Building configuration...
Current configuration : 144 bytes
interface TenGigabitEthernet1/1/1
description IND-CORE-9500
switchport mode trunk
channel-group 1 mode active
ip dhcp snooping trust
end
IND-IDF-08#sh run int t2/1/1
interface TenGigabitEthernet2/1/1
end
 - You may give it a try on the problematic stack , with the current advisory release :
                https://software.cisco.com/download/home/286313862/type/282046477/release/Amsterdam-17.3.4
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
8 Replies 8
Mark Elsen
 - Check if you may got hit by this bug :
           https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvi39202
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Says the current version i am on is a fixed version. I did inquire with TAC but not reviewing with them until Monday. All 3 stacks have same IOS Code as well right now. Two are working but i am worried it will be a matter of time before they stop now.
balaji.bandi
what is the other switches running Code - must be differrent than this, since this has bug i have encountered.
Try 17.X
BB
Same versions on all 3 switch stacks 16.12.4
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Upgrading code with Cisco TAC resolved the issue. There not sure which bug i was hitting but I was definitely hitting something regarding DHCP Snooping. Thanks everyone
Can you post show run inter port-chan X (from working and not working )
BB
just to be sure: did you configure 'ip dhcp snooping trust' on the port channel interfaces as well ?
