cisco 9300 switch not accepting any configuration
kirank10
hi guys
Our migration project is going on, we have brought 9300 new switch but it is not letting us give ip default route command nor if we configure vlans  switch is not taking the configuration .
What can be issue ?
kirank10
Hi guys
when i configured the SVI for VLANs 10 and 20, the switch created the corresponding VLANs in the VLAN database, making them visible.
i guess this behavior is expected , as configuring an SVI is a way to create and configure VLANs on a Cisco switch.
5 Replies 5
@kirank10 can you share error messages with commands which you tried. also the os version and exact model number of switch is required.
Good luck
KB
Mark Elsen
 - @kirank10  Also have a look at https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html
                                      and compare your settings ,
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Did the 9300 come with Meraki Cloud?
M02@rt37
Hello @kirank10
Could you please share the prompt you have ?
What is IOX-XE version and the exact platform you have ?
Finally, which licence ?
Best regards
kirank10
Hi guys
