Cisco ACE Application Control Engine (ACE10 and ACE20) Module
kamal kumar
Level 4
Level 4
Hi All,
We are facing a strange issue, our ACE 20 got failed due to power issue , after RMA once we are installing ACE 20 to 6509 , the status LED is showing ORANGE . The sh module shows it as " Others " ... The IOS is same as it was previously in 6509 .
Can someone please expalin , why such issues haapens and how to troubleshoot .
Thanks .
Dirk Woellhaf
Did you check your power (show power)?
regards,
    Dirk
(Please rate if helpful)
regards, Dirk (Please rate if helpful)
Hi Dirk,
yes indeed that is first level of troubleshooting ( Checking power ) .
we got following messages in Romon mode :--
Downloading NP 1 Image
..... 0x4b4b74 (4934516) bytes downloaded
............................................................ERROR: Unable to Clear RDRAM
Not enabling ecc/parity
Probable Cause :  IXP memory corruption
But one thing which really bothers me is that , this was a new RMA replaced module , so how come  it can show such issues .
