2960S-48TS-L take 10 minutes to boot and start, why?
Echo Chan
Dear Expert,
May I know why my 2960S-48TS-L takes 10 minutes to boot and start, some just take 1 minute, but one of them take up to 10 minutes, but after that it works fine, why?
Arumugam Muthaiah
Hi Echo,
Do you the console los while the switch bootup time? I am not quite sure why does it taking long time to boot but you could try this below option, then check the performance.
  • Reformat the flash
  • Download the IOS image again (make sure you have enough room avilable to copy image on flash drive)
  • Please ensure that you don't reboot until you verify that there is a good IOS image in flash.
  • Then reload the switch, and check the performance
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
thanks, let me check, I will come back to you when have the result.
