Cisco ACL how to allow TFTP
tedauction
Hello, can someone please confirm how to create an ACL to allow TFTP in both directions on an ACL from host 10.21.8.1 to any TFTP server in 10.0.0.0/8.
I have the following on my outbound ACL:
permit udp host 10.21.8.1 10.0.0.0 0.0.0.255 eq tftp
What would I put on my inbound ACL to allow TFTP back in ?
Thank you kindly.
Reza Sharifi
The access list should apply to the source interface as inbound (in).  Also, use the exact IP of the tftp server.
permit udp 10.21.8.1 host 10.10.10.10 eq tftp
in this example 10.10.10.10. is the IP address of the tftp server.
Thank you.
But how about the return traffic ?
What if I only wanted to allow TFTP return traffic ?
If the source is 10.21.8.1 (SVI L3) than you can apply the access list inbound to it as in
ip access-list extended test
than apply it to interface as in
int vlan 3
ip access-group test in
and test connectivity.
Julio E. Moisa
As Reza mentioned, here the sintaxis of an extended named ACL
If you are going to use named:
Ip access-list extended OUTBOUND
permit <protocol> <source host or subnet> <wildcard> <source port /ports> <destination host or subnet> <wildcard> <destination port/ports>
permit udp host 10.21.8.1 10.0.0.0 0.0.0.255 eq tftp  or 69
interface gX/Y
ip access-group OUTBOUND out
For inbound traffic, is similar
Ip access-list extended INBOUND
permit udp  10.0.0.0 0.0.0.255 eq tftp  or 69 host 10.21.8.1
interface gX/Y
ip access-group INBOUND in
at the end you will have.
interface gX/Y or Interface vlan X
note: if the source or destination is going to use dynamic ports you can ommit the port on the ACL, like the example above.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
