Cisco Aironet CAP702I configuration issue
rc00000011
I have problem with configuration of the cisco Aironet 702I. I can't  access to configure terminal option or to web setup. I search a solution to this problem and i found that the issue exist that the CAP702I  ( Controller based Access Point) is configured only by the controler . To return a CAP model to the SAP , I should update th firmware for a SAP702I.
I try to update the version of the firmware but always I found an problem , there is no boot to the image. You will found in theattachement an screenshoot of the error message .
I will apreciate all your help.
Thank you
0 Replies 0
