CPU Hog on C3750G
ritazreiby
i have logs on my Layer 3 switch that shows CPU HOGS from SNMP , what's weird is that is causing the OSPF adjacency to come down.
the Switch is a C3750G with IOS 12.2(55)
Is this a cisco bug ?
What can i do to reduce those errors ?
Jul 18 14:33:22.476: %SYS-3-CPUHOG: Task is running for (2097)msecs, more than (2000)msecs (2/2),process = SNMP ENGINE.
Jul 18 14:33:24.573: %SYS-3-CPUHOG: Task is running for (4195)msecs, more than (2000)msecs (2/2),process = SNMP ENGINE.
Jul 18 14:39:19.647: %SYS-3-CPUHOG: Task is running for (2098)msecs, more than (2000)msecs (1/1),process = SNMP ENGINE.
Jul 18 14:39:21.744: %SYS-3-CPUHOG: Task is running for (4195)msecs, more than (2000)msecs (1/1),process = SNMP ENGINE.
Jul 18 14:46:19.624: %SYS-3-CPUHOG: Task is running for (2097)msecs, more than (2000)msecs (6/5),process = SNMP ENGINE.
Philip D'Ath
Either try a newer software version if you have a Cisco maintenance contract, or reduce the size/quantity of SNMP queries being made to the device.
