Cisco ASA Trunking Problem
Steven Tolzmann
Hello all. I have setup a few trunks before between Cisco ASA5505 and CISCO 1252 access points, with no problem... However this one will not work for some reason, and I have been unable to find out why.. If I put the port into Access Mode, I am able to access the Access Point's Management Interface on the Native Vlan (1), but once I enable Trunking Mode on the port, all communication stops. The goal is to provide a trunk for 2 VLANS running on 2 SSID's.
EDIT: I did notice that the "switchport trunk native vlan " command is missing on this ASA5505 (only gives option for switchport trunk allowed), it does seem to appear in other versions. Is there a command I am missing somewhere to make this work?
Please help!!!
ASA5505:
ASA Version 8.0(2)
Licensed features for this platform:
Maximum Physical Interfaces  : 8
VLANs                        : 20, DMZ Unrestricted
Inside Hosts                 : Unlimited
Failover                     : Active/Standby
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
VPN Peers                    : 25
WebVPN Peers                 : 2
Dual ISPs                    : Enabled
VLAN Trunk Ports             : 8
Advanced Endpoint Assessment : Disabled
This platform has an ASA 5505 Security Plus license.
Switching Config:
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.9.1 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address xxxxxxxxxxxx 255.255.255.248
interface Vlan3
 nameif inet
 security-level 50
 ip address 10.10.0.1 255.255.255.0
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
 description TO ACCESS POINT
 switchport trunk allowed vlan 1,3
 switchport mode trunk
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ACCESS POINT CONFIG:
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(10b)JDA3, RELEASE SOFTWARE (fc1)
dot11 ssid INET
   vlan 3
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxxxxxx
dot11 ssid Inside
   vlan 1
   authentication open
   mbssid guest-mode
dot11 ssid Inside-5g
   vlan 1
   authentication open
   mbssid guest-mode
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers aes-ccm
 encryption vlan 3 mode ciphers aes-ccm
 broadcast-key change 3600
 ssid INET
 ssid Inside
 mbssid
 channel 2437
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.3
 encapsulation dot1Q 3
 no ip route-cache
 bridge-group 3
 bridge-group 3 subscriber-loop-control
 bridge-group 3 block-unknown-source
 no bridge-group 3 source-learning
 no bridge-group 3 unicast-flooding
 bridge-group 3 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 ssid Inside-5g
 dfs band 3 block
 mbssid
 channel dfs
 station-role root
interface Dot11Radio1.1
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0.1
 no ip route-cache
 no cdp enable
 bridge-group 1
interface GigabitEthernet0.3
 no ip route-cache
 no cdp enable
 bridge-group 3
interface BVI1
 ip address 192.168.9.254 255.255.255.0
 no ip route-cache
interface BVI3
 ip address 10.10.0.254 255.255.255.0
 no ip route-cache
5 Replies 5
Mhon Baul
Have you tried connecting the asa trunk port to a cisco switch with a trunk port? I believe your ap connection is directly connected to the firewall.
Reymon
Unfortunately I don't have a Cisco Switch to connect to at the moment. Is there a command missing on either device?
Thanks kindly,
Steve Tolzmann
Hi Steve,
 Can you do a show ver from your ASA? You should have a "security plus license" in order to configure trunk port on ASA FW.
Please rate  if this is helpful.
Reymon
Reymon,
I did post the show Ver in my original post. This ASA does have the Security+ License, and has 20 Vlans with Trunking Enabled.
The ASA Software version is 8.0 as well.
Steve
Have you tried removing the native vlan on below config since the ASA FW doesn't support this feature?
-Reymon
